![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Exhaust Tip Sizes. Which one will fit?
Which one of these exhuast tips will fit my '09 5-door LB? Each tip comes in two sizes. Not sure which one will fit.
http://www.autoanything.com/exhausts...A2440A0A0.aspx Outlet Size 3 5/8 x 2 1/2", Inlet Size 2.25", Length 4" or Outlet Size 4 1/4 x 3 1/2", Inlet Size 2.5", Length 5" http://www.autoanything.com/exhausts...A2445A0A0.aspx Outlet Size 3 x 4 3/4", Inlet Size 2.25", Length 4.75" or Outlet Size 4 x 4", Inlet Size 2.5", Length 6" |
![]() ![]() ![]() Drives: 2008 Yaris sedan A/T Join Date: Oct 2008
Thanks for the picture, but that doesn't answer the question...
DARK PHASE OF THE MOON
Drives: 07 liftback Join Date: Apr 2009
measure the damn thing
I would, but I have an old exhaust tip in there right now and don't have the time to remove it to measure. Also, I'm not sure what outlet size and inlet size are.
If you have a problem with me asking, why even post in this damn thread? Last edited by IsLNdbOi; 09-04-2009 at 03:03 AM. |
![]() ![]() ![]() ![]() Drives: Copper Orange Mica Yaris Join Date: Feb 2006
I think the one with length 6" might stick out a bit, I would suggest just buy all other 3 with different size and try to fit them yourself, keep the one you like and return the rest.
![]() My Copper Orange Mica Yaris with 9.3lb Kosei K1 TS http://www.yarisworld.com/forums/showthread.php?t=10951 http://www.yarisworld.com/forums/showthread.php?t=13882 http://www.yarisworld.com/forums/sho...180#post472180 |
Yeah, I don't really want a long exhaust tip either. I'm hoping the 4" one fits properly, but I'm looking for someone to confirm.
Diameter of the stock exhaust outlet is 50mm, about 1.96"... hope this helps...
This one fits the HB perfectly. The measurements are found in the link. You can find the same one at Walmart for about $12.
http://www.jcwhitney.com/autoparts/I...D:100000186093 |
#10 | ||
This one at 8" fits perfectly. Push it all the way back onto the exhaust pipe until it's flush against the plate, then center and tighten. It fits under the bumper quite a bit.
#12 | |
You don't have to attach it at the very end of the exhaust. Both tips you posted will probably fit but my touch the bumper. |
Also that tip kimona posted can be picked up at walmart for like 12 bucks and is pretty decent quality. It's no borla tip but pretty good for the price.
#14 |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
I gots me a Walmart tip!
#15 |
I have the square version of that tip from Wal-Mart. I got mine from Pep-Boys. It's shorter than the one from Wal-Mart, but it still makes the exhaust pipe look too long.
I'm going to try the Borla to see if I like it any better. |
#16 | |
Like PHXDEMON explains above, "You don't have to attach it at the very end of the exhaust." Push the tip back all the way until it fits snugly up against the exhaust pipe plate. Geez, a 10" long tip would be flush with the bumper edge. |
#17 |
![]() ![]() ![]() Drives: 07 YARIS HATCH 5 DOOR Join Date: Apr 2007
#18 |
![]() ![]() Drives: Yaris RUSH HatchBack Join Date: Jan 2009
from the attached picture.
i am pretty sure the middle one will FIT because that's exactly what i am using now... regards, hope this helps.. |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
| exhaust tip | DJ_stone | Cosmetic Modifications (Exterior/Interior) | 1 | 01-20-2009 07:52 PM |
| Exhaust Tip Decision | ruimond | Performance Modifications | 19 | 12-15-2008 12:49 AM |
| What aftermarket exhaust will fit the Yaris Sedan? | dngz | Performance Modifications | 2 | 10-02-2006 01:41 PM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
