| View Poll Results: Would you buy one? | |||
| No |
5 | 5.10% |
| Yes (for $75) |
46 | 46.94% |
| Yes (but it would have to be less than $75) |
7 | 7.14% |
| Yes (but I still want it to also display the time) |
40 | 40.82% |
| Voters: 98. You may not vote on this poll | |||
#1 | |
![]() ![]() ![]() ![]() ![]() Drives: Polar White - 5 Door '09 LB Join Date: Aug 2006
Also, to get outside temps. you'll need to sell a thermometer probe like the kinds used with Gentex and CIPA rear-view mirrors that show outside temps., right? |
#2 | |
Correct on the sensor probe for outside temp (although if I can figure out the CAN messaging for the A/C ECU, I can use it's outside temp probe and save people having to run a probe wire through the firewall). I am making great progress on this. I built a CAN bus interface this week and can read the PIDs (all of the standard OBD data), can read and reset stored DTCs, and can sniff the communication on the CAN bus between the ECM and the body ECUs. |
Progress, is good , you so need a Yaris Medal of Honor
#4 | |
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
#5 | |
![]() Drives: 2009 5D Yaris Join Date: Feb 2009
#6 | |
I'm using two PICs within the design. One dedicated to the CAN Bus communication and the other for the user interface, direct RPM sampling and temp input. The ELM PIC is way too expensive at $23 each. I built a code reader for ISO-9141 (K and L line comm) about ten years ago. The messaging for the CAN bus is very similar to OBDII, so most of my work thus far was redoing my hardware interface for CAN. |
#7 | |
well it's expected, it's really more of a hobby thing and i'm no CS major. But i have one way I can help out.. I've got a few ideas for making a attachable design; hopefully a design that would cost >5bucks worth of laser cut parts and possibly less in bulk. If you want to go with larger 2x24 or 2x16 LCDs instead i think it would be easy to make a housing and attachment clips for it. it may be a little more costly through this route but i think it would make a world of difference |
| in dash clock as tach? | Cosmonaut | In Car Entertainment + Electronics (audio / video / alarm) | 10 | 07-12-2010 12:27 PM |
| digital tach, 52mm, preferably blue leds | severous01 | Cosmetic Modifications (Exterior/Interior) | 5 | 05-15-2009 11:58 AM |
| Digital Tach | nqd | Performance Modifications | 4 | 05-17-2007 01:04 PM |
