Old 09-07-2009, 12:08 AM   #1
LEGATO``
LEGATO``'s Avatar
hmm okay
well the installation definitely seems easy enough with your diy brian. greatly appreciated
one thing; i just read peter's diy
and i know that he had to make the whole bigger for the projectors, but you didn't. and i dont own a dremel.
did you have to use a dremel for anything?
Project LEGATO
Old 09-07-2009, 12:14 AM   #2
Brian
Brian's Avatar
Originally Posted by LEGATO`` View Post
hmm okay
i used a dremel to cut a notch in the relector housing and to sand the paint off a spot for the grounging point. I'm sure you can get by with a flat file though. just might take a little longer.
Old 09-07-2009, 12:36 AM   #3
LEGATO``
LEGATO``'s Avatar
oh okay
thanks for the info
Project LEGATO
Old 09-07-2009, 01:41 AM   #4
Red Horse
Red Horse's Avatar
Drives: 2008 Yaris sedan A/T
no high beam?
Old 09-07-2009, 01:45 AM   #5
Brian
Brian's Avatar
Originally Posted by Red Horse View Post
no high beam?
Yes, it's a bi-xenon. Hi beam works perfect also. No pics yet though.
Old 09-07-2009, 06:13 AM   #6
JeremyG
Drives: Yaris Sedan Black
Brian, does this bulb looks the same as yours?
mine was labeled 6000K but I didn't expect the output was yellowish instead of white-bluish.
Oh yea one more question Brian, Does the H4 ring adapter sits your projector properly? or did you discard them to get your desire level on the light output?
JeremyG is offline   Reply With Quote
Old 09-07-2009, 01:13 PM   #7
Brian
Brian's Avatar
yes, its a D2S
Old 09-07-2009, 07:10 PM   #8
JumpmanYaris
USAF_SrA_E-4
JumpmanYaris's Avatar
Drives: C300 / Del Sol
Can someone fotoshop the headlights with the projectors in red housing? I am curious to see how it looks with the blk car lol
Originally Posted by sw07gt
Old 09-07-2009, 07:32 PM   #9
JeremyG
Brian, how bout this question?
Old 09-07-2009, 07:43 PM   #10
Brian
Brian's Avatar
It fit perfectly
Old 09-07-2009, 08:06 PM   #11
JeremyG
hmm looks like that adapter ring are purely for LH driver cause our (asia) design will shoot 140 degree angle with that ring fitted in... :(
Old 09-07-2009, 08:52 PM   #12
LEGATO``
LEGATO``'s Avatar
i was looking through one of the threads that peter put up and you asked him about his cutoffs
did you have any trouble adjusting yours or did you just plug them in and they were already set to go pretty much?
Project LEGATO
Old 09-07-2009, 11:19 PM   #13
Brian
Brian's Avatar
I tried to adjust them but since the projectors hit the reflector housing they barely went lower than
the factory setting. I liked the height of the cut off so I left it alone. Just got back from a night drive
and I saw absolutly no glare and a perfect cut off. The cut off height is perfect and doesn't shine
into other peoples mirrors. A huge improvement from running my previous HIDs in the stock
housing. With my previous HIDs there was glare all over the place and would constantly shine
Into other driver's mirrors. With the projectors there is plenty of light on the road. I must
recommend that anyone with HIDs upgrade to these projectors, atleast for the safety and courtesy
of the other driver's.
Old 09-13-2009, 08:01 PM   #14
JumpmanYaris
USAF_SrA_E-4
I am still waiting on my projectors, I think they might be in tomorrow.
Old 09-14-2009, 02:08 AM   #15
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
Hey brian, I've never had an HID kit before, so I was wondering if this was normal; When I turn on the low beams, it takes a few seconds to "warm up." It's not as bright at first. But then the projectors get brighter gradually, until it's peak. Are you experiencing this too? Or is this even normal?
Also, i've had this happen a couple of times; when I go to just turn the halos on, they won't turn on immediately. Maybe a few seconds, then they pop on. I know those don't have to "warm up," because I usually can just turn the halos on and they turn on right away. However, one time I tried to turn the halos on, and they didn't turn on. It wasn't until I flipped my lights on all the way ( to turn the low beams on ), is when the halos went on too. Then I turned the projectors off and just left the halos on, and it seemed to work fine after that. Very strange. It can't be a wiring issue, because all the lights DO work. It just depends on how long they want to take for them to eventually turn on ( the halos ). Hopefully this isn't a sign of bad things to come? dun dun dun.......
On a positive note, I've had many compliments on the headlights. I am extremely glad I went with blacking out the housings, and it gives my car a much more sportier, less eco-box feel IMO!!!!!!!!
Old 09-20-2009, 09:06 PM   #16
JeremyG
I had this problem too and culprit it's at the controller (square size little black box) that comes with the wiring harnesses. While having the issue of slow respond on the Halo (left side only), it will slowly died off.
Just to make sure that Box was the culprit, you can switch between the two Box to see which ones are faulty. There's a connector on the bottom of the box so just unplug them, not the whole wiring. Hope this helps.
Old 09-20-2009, 10:47 PM   #17
Brian
Brian's Avatar
I haven't had any problems with my halos so far. The only thing I can suggest is to double check
and make sure there are no loose wires.
Old 09-14-2009, 03:03 AM   #18
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
HIDs DO warm up, so its normal.
Check out my Build thread:
DIY Sedan Spoiler Install Kaotic Lazagna DIY / Maintenance / Service 36 01-19-2020 11:35 PM
How To Smoked Sedan Headlight -DIY zulhizainL902S DIY / Maintenance / Service 26 01-14-2011 02:12 AM
DIY needed for amplifier for sedan install YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 2 02-27-2009 10:07 PM
DIY Sedan Spoiler Install Interest? Kaotic Lazagna DIY / Maintenance / Service 28 09-11-2007 11:02 PM
