Old 09-15-2009, 03:24 PM   #1
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
Originally Posted by o89canucks View Post
I don't see a difference on leaning out a turbo vs. na car, leaning is leaning wether you have a turbo or not.
the difference is that the DSM guy is probably leaning to 14:1. turbos make engines more efficient, volumetrically and thermally (at low boost)
stoich is 14.7:1. that's what the yaris ECU is going to try to achieve in closed loop. leaning the engine out further will simply overheat the exhaust manifold, as well as your pistons, valves, everything.
so you'll get better fuel mileage at the cost of engine longevity, which does more harm to the environment than leaving well enough alone.
Originally Posted by xnamerxx
you nailed it sir.
Old 09-15-2009, 03:53 PM   #2
o89canucks
Mechanic from hell
o89canucks's Avatar
Send a message via Yahoo to o89canucks
Longetivity, yes, if you exceed safe temp ranges...which is what the egt gauge is for. Cast iron exhaust manifolds are made to withstand temperatures up to 1600F before doing major damage, I still wouldn't recommend running that hot for any extended period of time though. You still may get a decent gain by running egt temps 2-300 degrees over stock levels.
2007 Black Sand Toyota Yaris Sedan AT
2006 Sonic Blue Volvo S60R AWD 6MT
o89canucks is offline   Reply With Quote
