i've redlined my xA every day for 70Xthousand miles and never had a water pump (or any other) failure. stock pullies. redlining has nothing to do with it.
#2 | |
^+1 74k miles, redline a lot, stock pullies |
Modded Moderator
72k miles, redline a lot, aftermarket pulleys.
![]() I'm just saying don't be so quick to blame the pulley. There COULD be other factors. |
Modded Moderator
He also has been using an aftermarket pulley since 150k.
![]() ![]() Drives: 2008 Yaris S LB - MM Join Date: Aug 2009
The denial comes from ignoring the blatant admission of redlining the car everyday. Redlining DAILY will definitely do some damage under the hood. If your car was designed to cruise at 6/7/8 RPMs, then there wouldn't be a red line, period. I'm sure you've been doing some serious damage to your engine, especially considering that you most likely have stock (economic) internals. I don't see how anyone can argue in favor of redlining and against an aluminum pulley that is only 10% less than the stock pulley in circumference!
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 08:04 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| Water pump belt and pulley - replaced at 36,000mi | cleong | DIY / Maintenance / Service | 3 | 03-06-2009 12:12 AM |
| bye bye water pump | cali yaris | Performance Modifications | 29 | 01-03-2009 05:06 PM |
