Old 10-03-2009, 11:41 AM   #7
Yawesh
Yawesh's Avatar
Drives: 08 sedan at
The belt is very easy to change yourself, and if I remember right, I only paid $15 for the belt at Napa auto parts. You just have to loosed two bolts on the alternator mount, slip the old one off, slip the new one on, put a little tension on the alternator, and tighten the bolts. It was literally a 10 minute job to put a new one on Crashy.
just need regular rachet and socket right? u remember what mm is it? heh. thanks. i think our drain plugs are 14mm i forgot. should i wd-40 the bolts on the alternator first?
Yawesh is offline   Reply With Quote
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
Accessory Belt change. When?? mhkritzinger DIY / Maintenance / Service 12 10-23-2009 02:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
