Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
higher octane means less energy per gram of fuel
it only makes more power if: you have higher compression engine that can make use of the (obviously) bigger injectors, higher air/fuel compression pre-spark and pack more air in (bigger intake, forced air induction) or if you have a normal motor, but it is running crappy or has deposits on the cylinder, or for whatever reason the knock sensor is always retarding the ignition...then high octane might make the knock sensor quiet down and you'd get better overall performance. But this is treating a symptom not fixing the root cause High octane fuel in an engine that doesn't need it is a waste of money and you get less mpg all high octane does is, it has less tendency to detonate at the higher compressions, [so you can squeeze the crap out of it and then light it]. Now you get more power and speed, and perhaps the same MPG. but without high comp pistons, and special intake mods (turbo-blower) and an ecu designed for it...you will only end up with less power and less mpg with high octane. |
![]() ![]() Drives: Yaris 3dr Hatch/Black Join Date: Feb 2006
I've never owned a four-cylinder that actually like 87 octane (USA's lowest). I always end up using 91/93 and always get better power and mileage everytime.
When you drive a manual, you seem to really feel the smaller differences sense you are more attuned to the car's pulse. |
#3 | |
ordinarily use low octane. in a motor designed for 87 and above, (the Toyota VVT-i Yaris motor) and if it is has no maintenance problems, what you state is not possible except with bad gas...which can be a real issue depending on where you get your gas and the tanks they store the bulk in you simply cannot go faster and get better mpg with a hydrocarbon that has less energy content -unless - you boost compression and air Last edited by 127.0.0.1; 10-28-2009 at 08:04 PM. |
#4 | |
TSport Underdog
RIGHT ON THE MONEY!! EXCELLENT EXPLANATION !! KUDOS!!
#5 | |
Half a Bubble Off Plumb
| Fuel Efficiency and the Yaris | BailOut | Fuel Economy Forum | 327 | 01-02-2026 11:44 PM |
| Yaris Fuel Pump | HTM Yaris | General Yaris / Vitz Discussion | 12 | 03-22-2012 03:34 AM |
| My progression into hypermiling | BailOut | General Yaris / Vitz Discussion | 8 | 10-13-2009 06:31 PM |
| The last gas question | Tonavi | DIY / Maintenance / Service | 56 | 04-27-2009 08:40 PM |
