#1 | |
The brake fluid warning level wire (purple) and fog light indicator wire (red) need to swapped from pin 2 to pin 7 on that right connector. The alternator indicator wire (light blue in pin 1) needs to swap with the left turn signal wire (light green in pin 8). The check engine light wire (black in pin 4) needs to move to pin 5. The beam indicator wire (pink in pin 11) needs to swap with headlight power wire (gray in pin 14). The right turn signal wire (brown in pin 15) needs to move to pin 10. (the white in pin 10 gets pulled an taped off as there isn't a washer level low indicator). There's no input for the dimmer rheostat, hence the no dimming, but the JDM digital clusters have a magic button press sequence of the odo button that adjusts the dimming level. The JDM analogs may have the same. Put the odometer in "odo" mode. Press and hold the odometer changing button for 3 seconds. Auto dimming will toggle on or off. |
#2 | |
I applaud your work. What do you do for a job or are you that rich from selling ideas you sit at home doing drywall and modding Crashy?
![]() "Manual labour is not for me. In fact i'm not even sure non manual work is either." -Anthony Linton Check out ▬▬► I like I like ◄▬▬ for more fun on Facebook |
| DIY - Change your Gauge Cluster Color | vodkalush | DIY / Maintenance / Service | 89 | 04-29-2019 10:41 AM |
| FS: Gauge Cluster from '09 LB- $150 | MGargano | Items for Sale by private party | 14 | 10-05-2009 01:59 PM |
| Shifter knob/gauge cluster color | DevilGirl | Cosmetic Modifications (Exterior/Interior) | 3 | 08-11-2009 11:18 PM |
| Sedan Instrument Cluster to LB Instrument Cluster | Malaya1221 | Cosmetic Modifications (Exterior/Interior) | 2 | 12-02-2008 11:05 PM |
| CLUSTER LIGHTS WENT OUT | Go4th | DIY / Maintenance / Service | 23 | 01-25-2007 12:37 PM |
