![]() ![]() Drives: 2007 LB Join Date: Jan 2009
Try a different brand just for kicks. I'm betting something else previously mentioned is bent, out of round slightly etc. A different brand of bearing may have an ever so slightly different tolerance or materials etc and *might* have a different result. My old truck was going through the expensive brand bearings every 10k after it hit 90k. After a couple of sets of those I switched to the extra cheapies at AZone and damned if they didn't last for 30k. That truck was beat all to hell fyi.
#2 | |
Super Newbie
Drives: 2007 Yaris Liftback White Join Date: Jul 2007
Only thing I can think of is whatever is between the hub assembly and trans which is the drive axle. You already changed out the hub with a new toyota one which is the first thing I would of recommended to check. Motor mounts should be okay since the car is always moving forward because of the amount of miles on the car, 350K, which means it probably rarely sees any stop and go traffic to wear out the mounts. The only thing I can think of is the drive axle. Either its worn/unbalanced/distorted in way that causes a harmonic vibration at a certain speed to kill the wheel bearings that quick. From the high miles from delivery, it looks like its run at a certain speed continuously to obtain optimal fuel mileage and whatever that speed is, is where the harmonic vibration is worse causing the wheel bearings to fail. Also check for tire or wheel runout, or "out-of-round", maybe a combo of the two is causing the accelerated wheel bearing failure. I dont know the exact cause, just throwing some theories out there but I hope this helps you in your journey on getting the problem fixed! |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Jun 2006
I would have toyota look at it so if its fails after they fix it, they will stand behind you. 350,000 miles Im sure something else is going on but congrats I have 117,000 on my '07, going strong having only changed trans fluid, oil and filters and coolant, new set of tires, and new serpentine belt.
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris S Sedan 5-Speed Join Date: Oct 2008
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
350 thousand miles is amazing. With that kind of mileage its natural to have things wearing out. What amazing cars these Yari are.
![]() Drives: 2007 yaris 3 door Join Date: Oct 2009
ok sorry about the long wait but problem solved!!!! After i got the car to look at and giving it a good once over i noticed the trans and motor mounts had worn allowing the motor/trans to drop and shift to passengers side causing all of the stress which caused the constant bearing failures and transmission failure do to side load!! i hope this helps if anyone else has this problem!
Oh yeah i have had requests for pics of car and odometer and will as soon as i have a chance. P.S. the new trans mount is a much beefier unit from toyota! design flaw addressed???!!! |
| 2007 Yaris S 5spd Sedan doing 300,000 miles in less than 2 1/2yrs. | trini_per4mance | General Yaris / Vitz Discussion | 100 | 06-08-2022 09:54 PM |
| 2007 Yaris liftback, Philly suburbs, red auto, loaded, 30K miles, w/ trailer hitch | carlgt1 | Cars for Sale by private party | 11 | 07-10-2009 11:12 AM |
| forged rims Vs. alloys | red-jdm | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 07-23-2007 08:30 PM |
