Yeah. Probably a dumb question. I want to increase my fuel capacity so I can go further without stopping. As is it, I can drive just about as far as my 11mpg Yukon makes it before IT runs out of fuel. What's the fun in that? Anyone have any thoughts?
Flame away. ![]() And yes, my yukon really does only get 11mpg. The Yaris averages me out to mid 20's though. |
Forgive this thread. I've been up for 22 hours. I know it's not doable, at least according to my roomate, the Toyota master mechanic.
It'd just be so super awesome to spend the same amount of money as it takes to fill the yukon, yet drive around for 1200 miles before stopping again. only filling up 10 times a year though doesn't jive to well with big oil. |
Half a Bubble Off Plumb
I usually get around 370-400 miles on my 10 gallon fillups. I pass quite a few gas stations with that. A much larger tank would cut your mileage due to added weight, and you would be more likely to encounter problems with fuel going stale, accumulating moisture or being out of season with the changing fuel blends for different temperatures.
![]() ![]() Drives: 09 3dr (sold), 12 SE 5spd : ) Join Date: May 2009
Same here, I have never had less than 39MPG(first tank) and best of 44MPG. I guess if you want to pass more fuel stations you need to slow down a little. I know its no fun doing that, buts its the easiest way I can think of. Then you can get about 420miles out of 10 gallons or so.
Peace
Its all about the MPG's !! |
Yeah my truck will go 400 if I'm real easy and on the highway alot, so I'm passing the same gas stations, just at a higher cost. I can't imagine the weight of added gasoline could affect it that much...I don't have an exact figure, but I'm guessing gas is ~ water, which is 8#/gal.
I just think it'd be sweet to go further. My mom has an excursion with a 44 gal tank, diesel. When she fills that bad boy up, the computer regularly will calculate in the 700-800 miles to empty range...best I've ever done was 730, and it's awesome to be able to drive forever with out stopping. I made two round trips this month to the blue ridge from hampton roads, and still had fuel to run around town looking for the cheapest diesel. Hah could you imagine a yaris with present mpg and a 44 gal tank? ~1500 miles to empty, lol. |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
LOL..You're making excuses, if you want the range you will have to slow down.
I'm 260-280 lbs and my range is about 450-480 or so before I fill up again.
![]() ![]() ![]() ![]() ![]() Drives: 07 Yaris sedan Join Date: Jun 2007
Seems to me there is an "industry standard" for fuel tank capacity, usually works out to a range of 300-400 miles. Some vehicles have larger tanks installed for extra range, but nearly every car I've had in the last 55 years worked out to about the standard.
This is why I giggle a bit when someone says the made it from x to y on 1/2 a tank of gas; so does everyone else. Ask what the tank capacity is, and most have no clue... |
I love momentum.
Try riding a motorcycle with a 1.9 gallon tank. Get back to me after.
The Yaris' 11.1 gallon tank and MPG make the small tank a moot point. I rarely have to get gas. |
jesus. I've been in this particular forum for 5 hours and already I'm lead-footed AND burning the wrong gas. Yeehaw.
#11 | |
Drives: 2009 TOYOTA YARIS SEDAN Join Date: Aug 2009
No need to flame. It's obvious what your issues are. |
drive by with an 11 gallon tank b/c you only weigh 2k lbs... I get over 400miles to a tank...
$10.25/hr frying chicken
Is refueling really that hard?
I ♥ Yaris
Drives: Black 08 LB MT & red 97 Miata Join Date: Oct 2008
I understand the OPs sentiment... It would be awesome to put our outstanding MPG to use on a huge tank of gas, and just drive forever. The "passing up gas stations" phrase is a bit of a misnomer, as smaller vehicles generally have smaller gas tanks and similar ranges to larger vehicles. As far as the effects of a larger tank on a Yaris, if you were talking about a 44 gallon tank (like 4x the size of the standard tank), I imagine Yaris Hilton and the others would be correct about stale gas and water buildup. The weight would also be a factor of course. I do, however, think that a 20 gallon tank might work without too much water/gas problems. The extra gas (9gal) would weigh about 55.35 lbs (which really isn't that much) at about 6.15 lbs/gal (per wiki answers) and range would be almost double. The problem with that is: where in our tiny subcompacts would you put that huge tank, and if you took a hard turn would the back end kick out sideways when all 120lbs of gas suddenly sloshes sideways?
![]() I apologize on behalf of the rest of YW for the flames. Mpg is a hotly debated topic here, so you really picked a good one to start with. So welcome to YW, and just don't take it personally
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt. - Bertrand Russell Last edited by CtrlAltDefeat; 10-26-2009 at 03:28 PM. Reason: typo and slight recalculation on the tank sizes/weight |
#15 | |
I can't imagine watching the dollar signs roll by while pumping 44 gallons into a vehicle. Filling up from empty for less than $30 with my Yaris is much more palatable then dropping over $100 at one time at a gas station.
I'll put that 11 gals in my car and at legal freeway speeds (60mph)easily drive 6 to 7 hours with out stopping.
fuel cell in the trunk.
And I don't know how many more red flags you guys need for a troll... I mean comparing an excursion to a yaris in the FE forum? |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 06:41 PM |
