![]() Drives: 2005 Scion xA Join Date: Apr 2009
FS: 2005 Scion xA RS2.0 Turbo
Up for sale is my 2005 Scion xA Release Series 2.0 Turbo. # 196 of 1700
Here is a list of what has been done to this car. Engine: -1NZFE Rebuilt at 29000 miles for proper performance. -Custom Crower Forged Connectiong Rods. -CP Pistons Forged 8.5:1 Pistons and Wrist Pins. -CP Pistons Chrome moly piston rings. -Toga High Performance Main and Rod Bearings. -Engine block was machined for rods, honed, and decked. -All fasteners, gaskets, seals, o-rings and other misc. components were replaced with brand new OEM Toyota parts. -Scion xB Greddy Turbo kit that was completely customized for use in this car. -Turbo has been rebuilt with OEM Mitsubishi components -Completely custom intercooler piping by FujiiSPL -Greddy Type-S BOV (very hard to find) -Greddy Front Mount Intercooler -Mishimoto Performance Radiator -Perrin High Flow Fuel Rail -Perrin Silicone Radiator Hoses -OEM Scion tC 2AZFE 370cc Injectors -FujiiSPL Oil Feed line -Factory Air Conditioning deleted -Energy Suspenstion Motor Mounts -Ingalls Engineering Engine Torque Dampener -Custom 2.5" exhaust, High flow cat, no resonator, adapted to TRD axleback muffer. Great sounding exhaust! -Centerforce Dual Friction clutch package -Fidanza Aluminum lightweight flywheel -Thermal protection products from DEI Compression Tested after 500 miles; 182, 182, 185, 182 (1 to 4) Runs on 93 octane, Castrol Syntec 5W40 oil 4.5qts including filter Electronics: -Greddy Emanage Ultimate fully tuned by HolyRoller Dyno of Bow, NH -Greddy Profec B Spec II electronic boost controller -Greddy Full Auto Turbo Timer -Innovate Motorsports LC-1 Wideband AFR -Innovate Motorsports Wideband AFR gauge -Defi Blue Racer Boost Gauge -Defi Blue Racer EGT Gauge -Defi Blue Racer Water Temp Gauge -Defi Blue Racer Oil PSI Gauge Suspension, Brakes, and Wheels: -Tanabe DF210 Lowering Springs -DC Sports CS-2 Front Strut Tower Bar -Koni Sport Adjustable Shocks and Struts (these are the yellow Koni's) -Progress Rear 22MM Sway Bar -Energy Suspension Front Endlinks -Alliance Auto Sport 10MM Rear Hub Spacers -Brakes are stock except for a set of Wagner Ceramic pads in the front, and the car stops better than a stock xA. -Wheels Konig Next 15x7 Custom painted Gunmetal Time Attak Finish -Nitto NeoGen 205/50/15 on all four corners -Car will be sold with a complete set of tires on the vehicles stocck steel wheels which are studded up front for winter use with brand new generics all seasons in the back. Body: -2006 Scion xA front bumper conversion -JDM Toyota and IST rear Badges -Carbon Fiber OEM style rear spoiler -5000K HID H4 Hi/low kit -Two custom hoods will be sold with vehicle. The one that is currently one the car is a carbon fiber hood that has a 2001 Subaru WRX hood scoop molded to it, which had since cracked from heat and aerodynamic stress. The Other hood is the Stock OEM steel hood that has been custom Louvered by FujiiSPL. The OEM Steel hood has not been painted and the body work has been started but not completed. -Rear five windows are tinted at 20% -Custom vinyl graphics: Veilside inspired Japanese Cherry Tree, and Manufacturer names on the front doors. FujiiSPL sponsorship logos are going to be removed prior to sale. -Scion B Pillar Carbon Fiber overlays -Side markers and Turn Signals are tinted -Ventvisors for all four doors. Interior: -All Silver interior trim has been painted Gunmetal -Headliner custom wrapped in black cloth -Custom built three gauge a-pillar pod -ATI E-Pod steering wheel gauge pod -2006 Instrument Cluster Conversion -Scion xA stainless Door Sill Protectors -Scion Release Series 2.0 Blue Dash Lighting package -Vehicle will come with the Factory Headunit in place -Speakers in the door will be staying in the car. Infinity Reference 6012si 6.5" speakers. -Vehicle will be fully Wired for rear subwoofers. Subwoofers will not be included in the sale. -Vehicle will come with the Factory Release Series Front Seats installed. The Rear seat will be included, but not installed unless requested by the buyer. Seat was removed for weight savings. -Vehicle will be sold with rear hatch cover, floor and spare tire installed. -Scion Keyless Entry and Three Keys are included as well. -Vehicle will be sold with both front Sparco Seat Brackets Valued at $220.00, one is used the other is new. Additional Information: The car is sold as is with no warranty. Included with the car will be the instruction manuals for the turbo timer and boost controller. Also there will be two CD's included as well. One is the operating manual for the Innovate Wideband Controller and the other is a Factory Scion Repair manual on DVD. Vehicle Mileage: -Chassis: 36075 -Engine: 6000 Key Vehicle info: 1.5L I4 1NZFE, Aftermarket Turbocharged and Tuned 5 Speed Manual Transmission Spectra Blue Mica Paint OEM Code: 8M6 Car was dyno'd at 157WHP and 170WTQ on Stock internals, has not been dyno'd on the newly built engine. Overall Condition: Vehicle is in excellent condition. Runs very smoothly and strong. Incredibly powerful for a 1.5 liter engine. Makes approximately 185-200WHP on 12.5psi of continuous boost. No major flaws with the body, One ding on the Passenger Side Rear door and the usual minor clearcoat scratches. Absolutely NO RUST. The interior is kept in immaculate condition, with minimal wear. The car has taken home 7 Trophies over the last 2 years I have put it in shows. I have put countless hours of care and maintenance into the car not including the six months I spent building the new engine and turning it into a performance car. The car gets great gas mileage when driven considerately: 30-35MPG on the highway as long as you are not on boost, otherwise you can see 25-28MPG when you drive it spiritedly. It is very powerful for it's size and it's lightweight. This is truly no longer a Scion built for economy and shows, it is built for speed and performance. The engine alone has 10K in parts invested into it. Price: Asking price for this vehicle is $11,000 or best offer. Test drives are available, as well. A few pictures: ![]() ![]() ![]() ![]() ![]() ![]() Questions or Comments, feel free to post here or PM me! Last edited by uberegg; 12-18-2009 at 09:00 PM. Reason: additional info added |
your first post is to sell your car on YW?
Tiny Giant Clothing
Drives: 2008 Blazing Blue Yaris 3D LB Join Date: Oct 2008
i see that sucker parked down at the autozone in Rochester all the time!
Sold the yaris... rocking an 89 vw cabriolet now :) |
Tiny Giant Clothing
selling to get a yaris i hope :)
I was referred by a member on a scion forum to check out the forum here. I've been a member for a while, more of a lurker and reader.
The graphics are easily removable in no time. ![]() It's parked at Advance Auto in Rochester all the time. I'm a manager there. ![]() Selling this because I have picked up an '85 AE86 to work on. |
Tiny Giant Clothing
nice. I live over by home depot :) I see the car all the time when heading to barrington. its nice.
![]() ![]() ![]() ![]() ![]() Drives: 09 Yaris HB, 08 SR5 Tundra Join Date: Jan 2009
good luck with the sale... i do like that you replaced the scion badge with a toyota one.
![]() I crush you like tiny clown car, because you are clown, yes? |
#8 | |
Heel-Toe Hero!
Drives: GT-S AE86 Join Date: May 2009
that'd be me sir!
DailyDriver/Grocery getter-= 1986 Toyota Corolla GTS- SUPER FRESH 16v Hi-comp/TRD/LSD RUN 4AG! |
I used to have 1700 posts
that engine looks beautiful. did u have the entire block powder coated? how much did all oof that engine work cost you?
gotta start somewhere...
GLWS uber
37HSSV
OMG that is awesome!
I like the look, flow is nice. Engine is nothing more than a work of art, congratz on what can only be said as a Class A build.
07 Toyota Yaris Hatchback -sold- 11 Mazdaspeed 3 -SRI/TIP, 3 inch TBI, Custom FMIC, Tuned by Cobb Accessport, HKS ssq2 BOV, Upgraded HPFP- Clean stock look... Killer performance. |
toyota
men if youre in toronto id consider that in a heart beat..
Thanks for the comments everyone!
The engine was not powder coated, I painted the whole thing with a 2000 degree engine paint. The head and block are done in flat black, Timing and valve cover are done in gold. I don't have an exact cost of the money spent on the engine but to give you a rough idea: -1NZFE Rebuilt at 29000 miles for proper performance. -Custom Crower Forged Connectiong Rods. $800.00 -CP Pistons Forged 8.5:1 Pistons and Wrist Pins. $600.00 -CP Pistons Chrome moly piston rings. $80.00 -Toga High Performance Main and Rod Bearings. $120.00 -Engine block was machined for rods, honed, and decked. $350.00 -All fasteners, gaskets, seals, o-rings and other misc. components were replaced with brand new OEM Toyota parts. Approx $400.. -Scion xB Greddy Turbo kit that was completely customized for use in this car. $3000.00 -Turbo has been rebuilt with OEM Mitsubishi components Approx $175.00 -Completely custom intercooler piping by FujiiSPL $400.00 -Greddy Type-S BOV (very hard to find) $300.00 -Greddy Front Mount Intercooler $750.00 -Mishimoto Performance Radiator $200.00 -Perrin High Flow Fuel Rail $120.00 -Perrin Silicone Radiator Hoses $80.00 -OEM Scion tC 2AZFE 370cc Injectors $300.00 -FujiiSPL Oil Feed line $75.00 -Factory Air Conditioning deleted (Free) -Energy Suspenstion Motor Mounts $120.00 -Ingalls Engineering Engine Torque Dampener $150.00 -Custom 2.5" exhaust, High flow cat, no resonator, adapted to TRD axleback muffer. Great sounding exhaust! $600.00 -Centerforce Dual Friction clutch package $350.00 -Fidanza Aluminum lightweight flywheel $325.00 -Thermal protection products from DEI $275.00 Total: $9570.00 There are a few other bit's I didn't include just because I don't remember exactly which ones. Marcus, There are always ways of getting a car to Toronto.
#14 | ||
questions that I think any serious buyer would ask.
1. Quote:
And that new motor has 6000 miles on it? This is unclear (to me). 2. Quote:
3. What turbo is being used? Specs?
the greddy kit uses a mitsubishi turbo 14G iirc. it's not big, i ran a 14B originally on my setup, and switched to a VF39, for reasons unknown
Turbo is a Greddy TF035HL-14GK Mitsubishi turbo. This turbo Mitsubishi used on their turbo diesel Pajero line and also the same turbo used in the EDM Jeep Cherokee Diesel.
The 185-200hp is a guesstimation, I have not yet had it put on a dyno to get the actual numbers. With the current air temps here in New Hampshire it is much higher than that right now. It has not been re-tuned at the moment. The tune I have on it now was tuned for both half and full throttle. Under full boost with the stock internals the AFR's were holding 12.5:1. On the current set-up full boost sees about 12.0:1 AFR depending on air temps so it does run slightly richer. I can very easily change my fuel trims with minor adjustments on the laptop I bought for the car for data logging and engine management. This is with the adaptive ECU that Toyota loves to use with the 1NZFE and in the 6000 miles I have driven there has not been one DTC for a rich or lean condition on the engine or any Catalyst DTC's as well. Under cruise power at constant speed and with light throttle adjustments the engine hold the AFR between 14.5:1 and 14.8:1. And this is with the stock fuel pump and pressure regulator. With a small adjustment to lean it out, the car would probably pull another 20hp or more out of the engine. Conservatively, with the right adjustments the engine would make roughly 210-230whp depending on air temps. |
cool car man - deserves a very nice home!
rarer than JDM -1 of 1!
Another question a serious buyer would ask is who built the car, if not yourself?
And if you did it yourself, a little background on your abilities? thanks! |
| Scion xd turbo | PARIS | Yaris TS Talk | 22 | 02-26-2010 08:08 AM |
| Check out the new Scion iQ concept. In the States in 2011/2012 | LA Yaris | California | 9 | 10-23-2009 08:11 PM |
| 2005 Scion tC widebody | cali yaris | Cars for Sale by private party | 63 | 09-01-2009 02:20 PM |
| HKS turbo timer type 1 | Tamago | Performance Modifications | 3 | 07-21-2009 11:59 AM |
| Scion xD | Rudeshady | Central and South America | 1 | 06-25-2007 01:11 PM |
