Old 11-20-2009, 04:37 PM   #1
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
I'm gonna bet the primary effect in play here is the "toe curve" of the rear suspension. It's designed to be slightly toed in at the factory ride height, and as the suspension compresses in a turn, it toes in a little more for stability. This effect is all built into the rear axle assembly and the angles at which it rotates. So, by changing to the upper holes on a lowered car, you're effectively putting things back into the alignment they were designed for.
To verify this, someone should carefully measure their rear toe before and after making this change. If I'm right, you should see less static toe out after than before.
Old 11-22-2009, 12:53 PM   #2
kngrsll
Apexing Egg!!
kngrsll's Avatar
hmm,i need an alignment, perhaps i will try this...
HighTach Motorsports
2007 Toyota Yaris-ARGH!!
Old 11-22-2009, 02:05 PM   #3
YarisSedan
Drives: 08 Yaris Sedan
Hmmm i just had a alignment done few weeks ago. When i get a chance ill do this and get a second alignment done and see the difference and post results for you guys Ill also take a few pics more pics if no one has done it by then to make a little more detailed DIY for those who dont know exactly what we are talking about yet. GOOD FIND!
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 07:04 PM
Hyperco 5.5" single pigtail rear spring test kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 06-15-2009 11:11 AM
