#37 |
What?
I'm gonna bet the primary effect in play here is the "toe curve" of the rear suspension. It's designed to be slightly toed in at the factory ride height, and as the suspension compresses in a turn, it toes in a little more for stability. This effect is all built into the rear axle assembly and the angles at which it rotates. So, by changing to the upper holes on a lowered car, you're effectively putting things back into the alignment they were designed for.
To verify this, someone should carefully measure their rear toe before and after making this change. If I'm right, you should see less static toe out after than before. |
#38 |
![]() ![]() ![]() ![]() ![]() Drives: 2008 Polar White LB Auto Join Date: Oct 2008
Thanks for the finding! I'm curious though, what exactly is the benefit/gain of doing this procedure? I'm not quite sure I completely get what the end result is. Also, any negatives to it?
#39 | |
Apexing Egg!!
HighTach Motorsports 2007 Toyota Yaris-ARGH!! Mods: Tokico HTS, 6.6 kg F, 6.1 kg R custom springs, 23 mm RSB, 2-way TRD LSD, 15x7 +25 Team Dynamic wheels, 195/55/15 Dunlop Star Specs, Cobra Suzuka S |
#40 | |
#41 |
#42 | |
#43 |
![]() ![]() Drives: 07 Bitchin Blue HB Join Date: Jul 2007
Getting ready to put some DF springs on. Should I move them to the upper hole during the install? Where do you guys trust to do the alignments? I hate going to shops and have to explain to them how to do their job.
07 Yaris HB 07 Road King 06 Superduty CC 05 Scion TC 01 30' Sleekcraft HP500EFI ![]() Your Local Amsoil Dealer |
#44 |
Did you hand torque it down or just hit it with a breaker bar as hard as you could? I am guessing it should be torqued to about 145ft lbs. And maybe some threadlocker for some extra insurance. I am going to do this at home on my driveway hopefully tonight. Usually i hit everything down with a impact gun but by hand i like to get torque specs to be on the safe side.
#45 |
that's some serious torque there ...
#46 |
What?
Those pivot bolts don't need to be super-tight. The factory manual is available online, though... look it up!
#47 |
Is there some reason my question has been skipped over twice so far? Just curious.
#48 |
Ecurie Snoopy Lives
If you read above Lorens Posts
"I'm gonna bet the primary effect in play here is the "toe curve" of the rear suspension. It's designed to be slightly toed in at the factory ride height, and as the suspension compresses in a turn, it toes in a little more for stability. This effect is all built into the rear axle assembly and the angles at which it rotates. So, by changing to the upper holes on a lowered car, you're effectively putting things back into the alignment they were designed for." And on the previous pages you'll get an idea of how it adjusts the suspension geometry When you lower the suspension in the front you can get bump steer. There are devices to install in the front to adjust and compensate for this. This is something akin to that but in the rear suspension where you level out the torsion beam and realign the toe. I guess an illustration would be the best way to describe this.
Sponsors and Organizations: Toyota Rally Canada Yokohama Tire Canada Western Canada Rally Association Ecurie (Team) Snoopy Canada, racing since 1966 ![]() |
#49 |
What?
Um, yeah. I may not have addressed you by name, but your question has been answered. Read.
#50 |
#51 |
Dang, my crappy torque wrench doesn't go that high =(
#52 |
certainly does not need to. i removed my rear axle over 5 years ago and never used a torque wrench to re-install it. "tight" worked just fine.
#53 |
So whats the end end of this?
Raise the bolt location then X happens? Idk if people think a stable rear is better for handling? I'd assume that having a happier rear end, or a rear end with a TOE OUT setting is better for turning? That would also make the rear end feel like its gonna get in front of you, right? Ahh, Loren, help me out. |
#54 |
![]() ![]() ![]() ![]() ![]() Drives: car Join Date: Oct 2008
I would assume then this is for the Japanese following of the car for when it's lowered and being raced? Seems easy enough for me... Drill an extra hole for people who want to race it and leave one for the stock height...
Too bad it took us forever to find it =( |
| Any Yaris hatch rear suspension tweeks? | woof | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 26 | 12-05-2009 06:04 PM |
| Hyperco 5.5" single pigtail rear spring test | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 33 | 06-15-2009 10:11 AM |
