JDM Fred
IDK why anyone is worrying about the block or anything like that. If he isn't gonna build the engine and wants to push the limit I'd assume he'd want to do under 180whp. The question is how much is just right. I'm assuming about 160-170 would be the max and is plenty fast enough.
#3 | |
JDM Fred
OUCH! you know you crossed the line when you piss Garm off.
Bathroom + Laptop = <3
Damn then apparently my Audi has twice the amount of rice :-/
MS3 Driver
Drives: 2008 Mazdaspeed3 Join Date: Oct 2009
So it looks like you can't really push the stock block much past 150 WHP without problems with the internals.
12 second Yaris? Not gonna happen unless you have a built engine/turbo, stripped interior, and drag slicks. Even then... I don't know. Launching a FWD car is tricky stuff. I know you can't break into the 12s in an MS3 unless you are fully bolted on and a fantastic driver... or have slicks. Also, when do you have to up the injector size on the Yaris, and when do you run into fuel pump problems? How much possible WHP can you make on an NA motor?
![]() 08TrueRedMazdaspeed3 -PERFORMANCE: -CP-E SRI - PG TURBO INLET PIPE - GREDDY TYPE S - TRZ REAR MOTOR MOUNT- -OTHER: -STRIPES - EXHAUST RESOS DELETED - BLACKED OUT BADGES - TOWPLATE - HD LIP - - PROSPORT BOOST GAUGE/VENTPOD - STREET UNIT SHIFTER BUSHINGS - TINTED REFLECTORS/SIDE MARKERS/3RD BRAKE LIGHT - SIDE MOLDINGS REMOVED - |
![]() ![]() ![]() ![]() ![]() Drives: no-longer-boosted '10 Yaris Join Date: Nov 2009
i'm sorry, but a yaris with a turbo for everyday driving is riced out. my definition of riced out is un needed upgrades not gonna lie, i didn't know there was an actual deffinition. some cars come with a turbo, they are designed to work with a turbo but we are not talking about trucks or other cars, this is about a yaris. for me, work and back, school and back, a turbo on a yaris is a waste, if your gonna race, okay, put a turbo in. it all depends what you plan on doing. yes this is fourm is talking about making a yaris 12 seconds but without total engine mod it can not handle anymore then (i'll even stretch the limit) 200HP, it will blow up. since everyone has a smart ass remark, how else would you get a stock 1.5 L to over 168 HP without rebuilding it and modding it? and as i said before i have no idea what the block 168HP rating is, maybe its the ideal running HP everyone should get their car to, i simply stated there is a rating of 168 HP on the block, take it, do what you want with it. and without lots and lots of engine mods, you will never get a 1.5L over 200HP. driving a yaris with 200HP we are gonna have to send a search party for you on the moon. as i say over and over, revise it a little more at a time, the engine conponents are rated to 168HP, yes you could get away with 170, maybe even 180, after that, toyota has nothing to do with the failure of the engine. if you want to keep it from failure, rebuild the entire thing. yes you can put w.e mods you want and drive like they are not there but whats the point? really it all comes down to you, its your car, your money, the fourms are about sharing knowledge and trying to help out.
#8 | |
there is more than one member that has the stock block over 200 tuned. and its nitrous, not nitro. lol |
i am completly down with making a yaris real fast, but most of the stock engine parts will not take the super HP, pray as much as you like, its not changing anytihng about the engine
![]() Drives: 07 Yaris RS 3dr Join Date: May 2009
its more about the tune i bet with most of the engine failures you guys are seeing. with a good tune i bet this motor could see over 200whp all day long.
Every motor people think has a set limit untill someone pushes it.. Same thing happened with the KA-t.. people thought it would not hold past 300whp.. now guys have hit 500.. the 350Z people thought you would need a sleaved block to make any real power.. now people make 1000whp with a stock block with forged pistons and rods...
here is a civic with a non v-tech B18 that we pulled out of the junk yard.. build up a turbo kit and gave it a good tune, we ran the car and draged raced it for two years. one day we got gready and added more power.. the tunner said "today is the day its going to blow" and yep on the dyon we overpowered the cylinder wall.. but guess what the pistons were fine.. you could of reused them.... this was at 375ft.lbs.. that is the limit for that block stock. here is a a vid, we got it down to 11.1 on a stock motor... never opened up http://www.youtube.com/user/chummimc#p/u/28/1eonKVSNOtI |
Tamango took off his turbo kit awhile ago; thus why it's a NA xA.
My blitz kit made 140whp with 135 tq before i put on a custom overdrive crank pulley which added a couple more lbs of boost and made me at 136whp/140 tq. This was done in Hawaii weather on a dynojet. However, I am going to retune with the ultimate and tune accordingly for more power. I'm also installing a meth/water injection kit; and i have 1zz injectors and run 11-12 AFR at WOT. Nothing lean going on over here. In your mind it should. |
#13 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
WMI will give you good results. And yeah, it is my opinion about the racing. But I can voice it right? Don't place me as the bad guy because I believe something. I just would like to see 1.5's beat up on Evos and such on the track. Performance parts are developed for a performance enviornment. But anyone can enjoy extra performance anywhere it's all good. It's much more enjoyable on the track tho as I discovered. 136whp on a dynojet sounds about right. A typical Dynojet reads about 12% higher than our dyno. So that's about 119.
Ptuning.com |
#14 | |
And most people on here who have dyno'd their blitz kit have not even reached 133whp. So you suggesting that 136whp and what i previously hit before the pulley (140whp) is common for the blitz, I don't think it is. Atleast from the evidence shown so far. ps: I just got the meth kit installed and running. I know about that yaris; however, i remember reading somewhere about a yaris using nitrous that was in the low 14s or maybe even 13s? There was definately one in the states that I believe was in the 14s with just nitrous. He ended up blowing his engine on the strip. He posted a video of it somewhere on this site. He didn't want to say how he had the nitrous set up... |
#15 | |
Ptuning.com |
#16 |
Only Happy When it Rains
there is nothing wrong with doing something just because you can.
Colin Chapman disciple |
#17 | ||
[unsubscribed]
#18 |
JDM Fred
I really think everyone has the wrong idea of a Yaris (and a lot of Japanese cars). I give Garm a lot of credit for what he did but, a Yaris with 120whp can out handle a lot of things on a track. The car is meant for windy roads not going fast down a straight. If that's your goal go buy a new 2010 Camaro v6 for 23k or a used v8 mustang and call it a day.
| I'm going to drive my Yaris until they make... | bnther36 | General Yaris / Vitz Discussion | 2 | 11-10-2008 06:18 PM |
| Im trying to figure out a easy way to make my yaris fast... help! | nsracing | Performance Modifications | 61 | 04-11-2007 08:33 PM |
