Old 07-28-2010, 01:03 AM   #1
Jason@SportsCar
The head is back on with the new cams installed. A few hours in the AM and it should be ready to run.
Old 07-28-2010, 01:07 AM   #2
rob323
Don't drive it, RALLY it!
Drives: 1999 echo PRC rally car
Have any dramas with shims?
rob323 is offline   Reply With Quote
Old 07-28-2010, 01:27 AM   #3
Jason@SportsCar
I got it as a complete unit from our engine guy... Just had to pull the cams back out to put in the head bolts.
Old 07-26-2010, 08:48 PM   #4
justjesus
justjesus's Avatar
Drives: 2008 Liftback
Jason... show us the aluminum sexyness!!!!!!!
Old 08-10-2010, 12:28 AM   #5
Jason@SportsCar
Returned the new wheels. Just going to stick with the 15"s. I wish we could have made it work with the 13"s - the wheels actually worked, it was an issue with the manufacturer that we could not get past.
Old 08-02-2010, 11:13 PM   #6
knowmercy
knowmercy's Avatar
Drives: Blk 3door
Yeah, big cams make idle go to crap usually on a stock ecu. IIRC you're tuned via piggy back right? Might be time to retune with more air being sucked into the engine... but yeah, start with timing, go from there. Also, we need moar pictures!!
knowmercy is offline   Reply With Quote
Old 08-03-2010, 03:35 AM   #7
Jason@SportsCar
Currently we are stock with a Camcon, which wont do what we need now. We have a custom stand alone setup being built right now - sort of stand alone, we will still have the stock ECU for a few things.
Just finished all the body work, no time to check the cams yet. But it looks done for our shoot. Headed here in about 12 hours: http://wikimapia.org/16838231/San-Be...rations-Center
Doing a small feature for Toyota Connection magazine.
This will also give me a place to break in the engine and LSD.
Old 08-04-2010, 03:47 AM   #8
Jason@SportsCar
I am just not sure this new aero package will make the car faster.
The magic... When they are done it will look like the Yaris was going 100mph, instead of 1" a sec.
Got some miles on the engine and trans.
Old 08-05-2010, 02:59 PM   #9
Jason@SportsCar
Double checked the cam timing and everything is lined up. Our engine guy is convinced the stock ECU just cant deal with it. Fingers crossed that we get our custom harness and new engine management this weekend.
Old 08-05-2010, 05:32 PM   #10
Jason@SportsCar
It is a great day when the UPS man brings you a package you never ordered. One of our sales guys mentions the Yaris project to one of his advertisers a few weeks ago, and they built us a set of brake pads to try.
Old 08-06-2010, 04:21 AM   #11
justjesus
justjesus's Avatar
Very nice!!
Old 08-06-2010, 12:43 PM   #12
Jason, being able to set your idle might help. I have mine at 1100, I'm not sure the stock setting would work for me either.
Not always; we got a big box of porn once. It wasn't even good porn.
Old 08-06-2010, 03:18 PM   #13
Jason@SportsCar
Old 08-09-2010, 10:30 PM   #14
soloecho2
soloecho2's Avatar
Drives: 2004 Echo HB
Did you ever get the fiberglass front fenders ??
soloecho2 is offline   Reply With Quote
Old 08-10-2010, 12:24 AM   #15
Jason@SportsCar
No, there did not seem to be enough people interested to make it worth doing. So we just went back to flares on stock fenders.
Old 08-10-2010, 03:15 AM   #16
"an issue"?
PM me the details, maybe I'll pick them up.
Old 08-10-2010, 01:27 PM   #17
Jason@SportsCar
"an issue"?
I won't go into detail about why we chose not to use them, or who we got them from at this time. I am certain in your position you see first hand how dealing with the wrong manufacturer can be bad for business.
Any time we do something for use in the magazine we have to decided if we would spend our own money on the product/service/etc, and would we recommend this to someone else... The answer to both of these questions became no.
Personally I hate not using them. The 13" wheel/tire package was going to do so many good things, better gearing, lower CG, less weight. Ultimately I believe not having them will slow us down some at the Runoffs. But it is to late to do anything about it now, and ultimately you have to draw the line somewhere.
Old 08-10-2010, 01:32 PM   #18
Jason@SportsCar
On a happier note... Last night I pulled out the CamCon and associated wiring, and got the stock harness all patched up. I can now plug in our recently delivered custom plug-n-play harness for our new engine management. Going to get it tuned tomorrow.
We have also scheduled the first installment on the Yaris to go in the Oct issue of SportsCar, which we are working on right now.
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
