Old 02-08-2012, 03:41 PM   #1
Jeff@MicroImage
"Know it all"
Jeff@MicroImage's Avatar
Drives: Lancia Delta Integrale
Are you still running VVT-i in this car? Does your tuner/management have control over the that?
www.microimageonline.com
Jeff@MicroImage is offline   Reply With Quote
Old 02-08-2012, 03:48 PM   #2
Jason@SportsCar
Yes, still running it and the AEM controls it.
Old 02-08-2012, 04:01 PM   #3
Jeff@MicroImage
"Know it all"
Great results! I'm real excited to see that these actually work. I'd be curious to see if any top end gains or benefit from disabling VVT-i and running set or manually adjustable cam gears. Might loose more torque though...
Can't wait to see what the turbo spec Jun cams do for boosted cars
Old 02-08-2012, 04:04 PM   #4
Jason@SportsCar
The low end gets really weak with no VVT-i control.
Old 02-17-2012, 02:49 AM   #5
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
pics
From runoffs
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 03-13-2012, 10:45 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Wow, I'm surprised to hear that there's so much involved in fitting those gears. The C-56 gears went in without much fuss, but I'm stalled on funding for replacement parts and the LSD.
Old 03-14-2012, 02:31 PM   #7
Jason@SportsCar
It is odd, these were supposedly built for the C56. Are you pulling parts out of a C56 A or B? Could be the difference.
Turns out the gear itself is not to wide, but the collar at its base, that combined with the Yaris synchro made it bind up. And it is only the 3rd and 4th on the input side that is the challenge. They take a little bit off the collar and install the Celica/MR-S synchro its supposed to fit.
Fingers crossed.
Old 03-14-2012, 10:46 PM   #8
racerb
Back in my Honda racing days this guy was the man for alternate gear sets, he can probebly help you out if need be. He is a multi-time SCCA Champ and really knows a thing or two about gearboxes.
http://www.housemanautosport.com/
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-14-2012, 11:44 PM   #9
Jason@SportsCar
racerb
He was the first person I talked to when we started looking for gears two years ago. He was willing to make a custom final drive, but we found the xB gear fit at a fraction of the cost. He had no interest in doing the dog engagement trans that I wanted.
Old 03-15-2012, 08:18 AM   #10
CrankyOldMan
Fingers crossed.
I'm afraid you've got me stumped on that one. I didn't realize there were two C56 variants, or at least that there were significant internal differences between the front and rear mounted versions.
Old 03-16-2012, 10:59 PM   #11
racerb
Toyota must have a big range of different gearbox versions, my S-53 is fairly common, but I ended up with a JDM box and can't find syncros or shims to fit it! Would love to find an alternate final drive, the 4.18 is just not working for our longer tracks here in the East.
racerb
racerb
'86 Celica GT
'87 Celica GT-S
'98 Rav4L
'01 Tundra SR5
Old 03-16-2012, 11:25 PM   #12
Jason@SportsCar
C56A open diff
C56B LSD
You may actually have the same problem we did and not know it yet if you have not put it back together. You wont know until you jam it all in the case and measure the drag when you spin it.
Old 03-17-2012, 12:15 AM   #13
CrankyOldMan
It's definitely a C56A then, as it's an open diff. The assembly goes together at the moment, but I haven't checked the torque yet. I have to replace the output shaft inner bearing (the one in the bell housing) because the C56 has an inner race on the roller bearing, whereas the C50/C59 doesn't, and the groove where the snap ring holds the inner race on the shaft sits right in the middle of the rollers. I'm assuming that you weren't able to get the torque set properly with any of the shims, which prompted you to investigate?
Old 03-27-2012, 12:39 AM   #14
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Do you know what the new ratios are?
Old 03-27-2012, 08:48 AM   #15
CrankyOldMan
I don't want to spoil the surprise, but I think I've cracked the source and specs for these. Could you confirm if I have the specs right?
3rd - 28:19 (1.474:1)
4th - 29:24 (1.208:1)
5th - 25:26 (0.962:1)
Jason said that he hadn't counted the teeth on them, but I'd be willing to bet that these are in fact the new ratios. 1st and 2nd are integrated into the input shaft, so he's stuck with 3.545:1 and 1.904:1 respectively.
Old 03-27-2012, 01:18 PM   #16
Jason@SportsCar
I did not count the teeth, but Jeff @ MI did, and they were not the same counts as what you have found on the OE parts you pulled from the other boxes.
Yes, 1st and 2nd stay the same, and I would not want them any shorter. With our final drive and tire size 1st is only useful for getting on the trailer. With 2nd good only to 62mph, it is only used on very tight turns, any shorter and we would have to use 3rd for the slow stuff.
The new ratios are:
3rd 1.474 Kaaz
4th 1.208 Kaaz
5th 0.961 Kaaz
With this setup on most tracks we will use four gears VS only two or three with the current setup, offering much better acceleration. We will see 120mph in 5th at our redline, perfect for Road America.
Old 03-27-2012, 03:44 PM   #17
just got my new issue of car and driver today....they did a b-segment racer comparo....kia, honda, mazda, mini....where was your toyota?
Old 03-27-2012, 04:27 PM   #18
ROCKLAND TOYOTA
TRIM HUNTER
ROCKLAND TOYOTA's Avatar
late comer i quess.....
Hood Stay (lift) Instal 1NZYaris1 DIY / Maintenance / Service 31 09-22-2016 08:56 PM
The opposite sex can't stay away with ssk POORSHA DIY / Maintenance / Service 20 08-19-2009 11:41 AM
eTiMaGo Stay safe Bob_VT Off-topic / Other Cars / Everything else Discussions 20 12-02-2008 06:31 PM
Tuned a DBW Toyota yesterday Turbo&Auto Performance Modifications 17 08-17-2007 01:04 AM
why am I always here?! wtf...i cant stay away.. Blenjar Off-topic / Other Cars / Everything else Discussions 5 02-26-2007 11:51 AM
