![]() ![]() Drives: 07 Mazda MX5 Copper Red Join Date: Jun 2009
Fed up with rubbing... heres my plan
My current setup consists of OEM shocks with Tein S-tech springs, 17x7 +45 Team Dynamics with 205/40 tires, factory alignment. My ride height is 12.5" all around center of hub to fender.
I am getting rubbing in the front on almost every bump and it is really annoying. Turning at low speeds does not rub at all. The rear are fine even with a 12mm hub spacer. My plan is to get an alignment with -2 camber and 0 toe in the front and from my calcs, I can move the upper outside edge of the tire ~.4" in. I have on the way: Tokico blues, TigerTec springs <a bit milder drop with a little higher spring rate in the front>, and a 23mm rear sway. How does this sound? I have a lot of $$ invested in my rims and tires and want to keep them. The rims are really light <for 17's anyway>. I can switch to 195/45 tires and gain some width clearance there but lose some wheel well clearance <they are a little taller than the current tires>.
Brent Former Yaris Owner |
| anyone rubbing with df210 on 205/45/17 | marcus | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 07-09-2009 10:59 AM |
| Rubbing | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 06-06-2009 03:32 PM |
| Dealing With Rubbing | nqd | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 42 | 04-24-2009 01:56 PM |
| hard to find anything that's NOT 38 or 40 offset... will these fit without rubbing? | tonyg | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 03-19-2009 08:53 PM |
| Rubbing: 185/60/15 w/NF210's | songa | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 10 | 12-10-2008 05:09 PM |
