Old 04-19-2006, 05:55 PM   #1
RallyYaris
RallyYaris's Avatar
Drives: Ford Windstar 1996
TRD supercharger from Scion?
Anybody know if the new supercharger from TRD for the Scion tC will fit the North American Yaris engine (1.5 L)?
RallyYaris is offline   Reply With Quote
Old 04-19-2006, 07:07 PM   #2
jdgriswald
5-Door Envy
jdgriswald's Avatar
Drives: '08 Scion xD
Not if it's for the Tc, it's a 2.4L (2AZ-FE). Yaris is a 1.5L (1NZ-FE).
jdgriswald is offline   Reply With Quote
Old 04-20-2006, 02:05 AM   #3
riceboy
Drives: icebox
You might be able to fit the TTE blower into the Yaris... check it out under the 1st gen under compressor kit....
http://www.tte.de/cm_yaris_P1_Facelift.htm
riceboy is offline   Reply With Quote
Old 04-29-2006, 01:07 AM   #4
C2AUTOSPL
Drives: 240sx, 00 Celica
Doesnt Blitz make one for the Yaris already?
C2AUTOSPL is offline   Reply With Quote
Old 04-29-2006, 09:58 AM   #5
riceboy
Drives: icebox
Yup Blitz has already got a unit for the Yaris which is pretty much a direct bolt on, I think everyone wants TRD to release one because then you could have some sort of warranty attached to it. If you're more adventurous the previous gen echo hb blitz compressor can also be retro-fit for use in the Yaris. Greddy has also just released a supercharger for the xB which could probably be retro-fit for the Yaris. Though retro-fitting anything is a lot of work...
Old 05-06-2006, 01:01 PM   #6
evolutionist03
Drives: 2007 Toyota Yaris Hatchback
Send a message via AIM to evolutionist03 Send a message via MSN to evolutionist03 Send a message via Yahoo to evolutionist03
Does anyone knows the price of the Blitz supercharger? And what is power boost?
evolutionist03 is offline   Reply With Quote
Old 05-06-2006, 03:32 PM   #7
Idjiit
5 Stars, Bitches
Drives: Prius, Silver Yaris Liftback
$3,500 and 30% over stock at the highest setting.
Idjiit is offline   Reply With Quote
Old 05-06-2006, 05:03 PM   #8
evolutionist03
Ohh! 30% over? Wow, sounds pretty good! Now, teh price of $3,500 is installed, or just teh MSRP of the Supercharger only? Thanks BTW! I appreciate the info!
Old 05-06-2006, 05:17 PM   #9
Idjiit
5 Stars, Bitches
MSRP for the kit, not installed.
Old 05-06-2006, 05:19 PM   #10
evolutionist03
I see. Thanks for the info! Is there a web site that I can get all the specifications of this supercharger? I am in the mood of getting one! LOL.
Old 05-06-2006, 08:41 PM   #11
riceboy
Drives: icebox
http://www.blitz-performance.com/ You'll be looking for the Scion xA/xB compressor kit.
Old 05-23-2006, 11:52 PM   #12
YarisHatch
Drives: Blank
Send a message via AIM to YarisHatch Send a message via Yahoo to YarisHatch
Nope, its for the 2az 2.4l. Also incase you were wondering, the trd japan kit for the bB/Ist won't work either due to the different lay out, different engine code, sensors, and ecu.
Kits such as blitz/greddy/power enterprise made for the Xb might fit providing that it can clear the hood, and piping clear without rubbing against anything. A company called ZPI is putting out a turbo kit for the xb/xa that will produce an estimate of 180whp, you might want to look into them if you want to make power. zeropointindustries.net, go there and email Kenny. Hes a good guy, if their kit doesn't work with the Yaris they might be able to modify the kit for it to work. I'm not sure if the sensor placement is different though, i know it's different from 05' to 06' 1nz's for the Scion line. The Ecu is also mapped differently.
YarisHatch is offline   Reply With Quote
Old 05-24-2006, 07:27 AM   #13
echo_hrs
Around the universe...
Drives: Uber-Evolved Pokemon
echo_hrs is offline   Reply With Quote
Old 07-14-2006, 05:53 AM   #14
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Originally Posted by echo_hrs
Old 07-14-2006, 08:57 AM   #15
boxerboy
Drives: WRX ,Tacoma and Yaris
There is one thing that may or maynot have been said, but why? The Yaris is to save on gas (money). Put the boost to it and you will not get 40mpg and you will also need premium fuel, which will be about $.20 a gal. more. Both of my other cars are boosted. I have a 02 S/C tacoma I have not had any trouble with it that has cost me any money. The biggest problem is low rpm full throddle in a high gear. Not enough fuel. Thats the only flaw that I have seen. I also have TRD headers and exhaust. I think the trans will need a rebuild sooner than a non S/C. More power is always good but at what cost?
boxerboy is offline   Reply With Quote
Old 05-24-2006, 08:15 PM   #16
silverRS
Drives: 2007 Yaris RS Silver
hmm sounds really tempting but that alot of cash for such a small supercharger, aren't turbo's allot cheaper?? Cant I buy a TRD turbo or will that not fit either??? damn you Japan
silverRS is offline   Reply With Quote
Old 05-24-2006, 11:05 PM   #17
YarisHatch
Drives: Blank
As i stated before, the trd turbo will not work with the usdm 1nz motors. The japan 1.5l's they use are a different engine code, different sensors, totally different ecu and their gas is much different. Why does this matter? The trd turbo puts out 136whp on the 1.5l bB, however that is with 101octane. Sounds so high here in the states but yeah, makes a huge difference. Point? Even if you could manage to run with it (impossible with the motor and usdm ecu) you wouldn't see gains above 30whp, i.e 110whp.
As a general rule, turbos are about the same if not more expensive than a supercharger. Also maintanence is much higher on a turbo than a supercharger. Very rare do you not have to tune a kit even if it does come "pre tuned" with a piggy back system. Even so, after a while tune ups are a must. Worth it? Turbos almost always make more power per psi than a supercharger. Design is everything when it comes to boost.
Here are some prices too for the boost applications i mentioned, keep in mind i still don't know if these will actually fit and work in the yaris bay. Even if it did, i believe the 1nz in the yaris shares the same ecu as the 2006. 95% of all kits out there right now are for 2005 or older. Ecu maps are different as well as a few o2 censors.
Blitz - $3,000
Power Enterprise - $3,200
Greddy s/c - $2,600
Greddy t/c - $2,800
ZPI turbo - $3,600
Custom - $2,200+
I just rounded to a middle average, some sell these kits for cheaper, some sell for more. ZPI you can only buy at zpi and one or two other websites, usually kenny will hook you up in deals.
Heres tack on prices that would be a must that most forget about: Upgrading injectors, performance belts, good fuel management, upgraded pistons, full synthetic tranny oil, full synthetic motor oil, stage 2+ clutch (manuals), shift kit (auto), atf cooler (auto). To get the most out of any boost application with our motor i'd also recommend motor mods, especially 2.5'' exhaust for boost. (2.25'' exhaust for n/a...not talking about tip, talking about piping)
All in all, you are looking at atleast $5,000+ after all the parts you need to have to ensure a long lasting motor under the extra power and stress, and tuning..some things i mentioned you don't have to have, some are usually included in the kits but not all.
Old 05-25-2006, 04:03 PM   #18
Calidrifter
Drives: 1997 Nissan 240sx
Yeah but a supecharger is constant hp throught the band and you do't get turbo lag. Also with any turbo upgrade if you plan on running over 7 psi you WILL need to get new internals. And from whtaI have been hearing the 1NZ has pretty weak internals already, so don't be surprised to see some dumb kids in here with a ""I blew up my engine" thread in here.
Calidrifter is offline   Reply With Quote
Vitz RS TRD Racing jdgriswald General Yaris / Vitz Discussion 12 05-13-2010 02:53 AM
Toyota's Yaris TRD VitzBoy General Yaris / Vitz Discussion 10 07-24-2006 08:10 PM
