Old 01-03-2010, 02:28 PM   #11
Kaya B.
Drives: Yaris
OK. Do you have a volt meter? That pin is definitely the one that controls turning the running lights on or off. For the US version of that module, letting that pin float (cutting the wire) works. For your version, if we can measure the voltage from the blue wire to the chassis ground with the engine running and with the headlights off and then with them on, we can figure out if that pin needs to be tied high or low on your module.
yes, thats already in my mind. i'll check the pins with voltmeter.
but i'm back from holiday i don't know when can i find time to try :(
thanks for everything. i'll give information again when i'm done.
Kaya B. is offline   Reply With Quote
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 04:12 PM
