Old 01-05-2010, 10:35 PM   #1
DerFlosser
DerFlosser's Avatar
Drives: Yaris
I have owned so many deep dish wheels and owned those exact wheels in the stock silver finish with flat caps and can tell you that to fit on a yaris, you will need atleast 3.5 degrees of camber along with rolling the fender. Unless you want to wear a mouthpiece when you drive...then you might be able to get away with less camber but you'll still have to pull/roll. Looks good though...especially on white.
DerFlosser is offline
Old 01-07-2010, 01:31 AM   #2
ctrj
Drives: 07 Yaris Sdn, 97 4Runner
Is stretching the sidewall like that safe?
RJ
2007 Toyota Yaris Base Sedan -5 speed
SOLD
ctrj is offline
Old 01-07-2010, 05:46 PM   #3
jekqmb
Local Sh*t Disturber
Drives: 2009 Yaris LB
Hey i would go -3 with a rolled fender and you should be good, cause you want it prefectly flush with the lip. This is going to be awesome!
jekqmb is offline
Old 01-07-2010, 10:16 PM   #4
Black Yaris
der Zeck
Black Yaris's Avatar
no it is not
Black Yaris is offline
Old 01-07-2010, 10:38 PM   #5
DerFlosser
DerFlosser's Avatar
Drives: Yaris
no it is not
Why is that? I have never had any issue at all with stretched tires. As long as they are inflated properly, they should be just fine.
Old 01-07-2010, 06:21 PM   #6
hatchblack
hatchblack's Avatar
Drives: '08 yaris hatch
walter, that fitment will look sweet! you can't let the vdub guys have all the fun!
hatchblack is offline
Old 01-07-2010, 09:31 PM   #7
minired5stby
minired5stby's Avatar
Drives: Yaris S liftback
Whatever you end up with I'm sure it will look sick bro.
minired5stby is offline
Old 01-07-2010, 11:16 PM   #8
Black Yaris
der Zeck
stretching tires puts extra stress on the sidewall, and tires are not meant to be seated at that steep of an angle. If you over inflate to keep the tire seated you put even more stress on the sidewalls, and if you under inflate to keep the stress down on the sidewall, you run the risk of unseating the bead.
Over all forcing something way beyond it's normal limit is usually a bad idea
Old 01-07-2010, 11:49 PM   #9
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Stretched tires lol
PHXDEMON is offline
Old 01-07-2010, 11:51 PM   #10
PHXDEMON
PHXDEMON's Avatar
seriously though I would never stretch tires for the following reasons
Tires distorted due to being fitted to too wide a rim requiring much higher inflation pressures to prevent excessive wear on the edges of the tread surface
Rough choppy ride due to higher inflation requirements
Likelyhood of actually having the tire coming off the bead if impacted
Higher wear rate on suspension components
Higher wear rate on wheel bearings
Poor directional stability due to wrong offset being used
PHXDEMON is offline
Old 01-08-2010, 12:01 AM   #11
PHXDEMON
PHXDEMON's Avatar
This actually originated on euro cars due to laws passed that only allowed a certain width of tire tread on vehicles. So people started running ridiculously wide wheels with the same size tires to "rebel" against the new standards.
PHXDEMON is offline
Old 01-08-2010, 10:47 AM   #12
DerFlosser
DerFlosser's Avatar
Drives: Yaris
Never heard of any of those complaints from anybody running stretched tires. I don't find the ride quality any different and suspension components are doing just fine. The biggest problem I can see is unseating the bead. Aside from that, I think most of the rest of the complaints against stretched tires don't really hold up very well.
Old 01-10-2010, 10:30 PM   #13
marlondog
Shut your fricken suck!!!
marlondog's Avatar
Drives: 07' liftback
GDF's: God Damn Flushaholics!
marlondog is offline
Old 01-11-2010, 01:25 AM   #14
+1.
phxdemon, state your source for all the claims in post #28 -- then we can have a real, informed discussion on the matter.
cali yaris is offline
Old 01-12-2010, 06:15 PM   #15
supmet
Drives: 2007 4 Door Yaris
+1.
How about you find one tire manufacturer that recommends putting a 205 tire on a 9 inch rim, and then we can have a discussion. Or Racerfreak can put up a link of a "pro drifter" using some ridiculous stretch. I'm not talking 5-10% out of specs, I'm talking a 205 on a 9 inch rim
supmet is offline
Old 01-11-2010, 03:40 PM   #16
Tamago
Start another Oil Thread!
Tamago's Avatar
Drives: ZZW30
common sense would tell you that a stretched tire is not as safe as a tire on the correct width wheel:
1. grip is reduced
2. tire will be much hotter during operation (you are placing more load on the sidewalls, because they're designed to support weight on a "vertical" plane, not leaned over to the side. because the sidewall of the tire is now being stressed outside of it's safety zone, the extra movement of the sidewall during motion will create much more heat
3. more heat = less speed capability. if the tire is rated to 118mph on a stock wheel, give it about 80mph stretched.
4. when you stretch a tire, you are creating a "cup" in the center of the tread. this leaves the "corners" of the tires pushing more onto the road unless the pressures are raised internally.
5. raising the internal pressure of the tire to prevent weird wear patterns decreases contact patch, and increases growth during the hot cycle (see boyle's law)
common sense people.
stretching is for poseurs and show queens. would you trust your life to half a comdom? no? you'd rather have a whole condom in place during intercourse? but a half a condom looks so much more "flush"!!
Originally Posted by xnamerxx
you nailed it sir.
Tamago is online now
Old 01-11-2010, 07:22 PM   #17
YAR1S
YAR1S's Avatar
-Jen <3
YAR1S is offline
Old 01-11-2010, 08:33 PM   #18
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
1. grip is reduced
people in touge and drift have been stretching there tires for plenty of years and you don't see them complaining. Drifting requires maximum grip out of a tire and I see lots of pro's stretching. Although most of those people actually care a lot about show, but to each their own. No one said you had to stretch tamango.
I give the op credit just for trying it
RacerFreakXXX is offline
Test drove Rio5, Fit, and Yaris all today kmf123kmf New YARIS Purchase Forum 16 10-02-2009 08:48 PM
CtrlAltDefeat - Photo-Scavenger Hunt CtrlAltDefeat Photo-Video-Media Gallery 0 03-04-2009 03:14 AM
Zefoxe - Photo Scavenger Hunt Zefoxe Photo-Video-Media Gallery 0 03-02-2009 11:23 PM
thewifesyaris - photo scavenger hunt thewifesyaris Photo-Video-Media Gallery 0 03-01-2009 07:02 PM
