Old 01-08-2010, 05:53 PM   #10
cdydjded
Drives: Yaris LB Turbo
My head is ported and polished, but otherwise stock, no work to the cams or valves. My redline is set at 7200.
When you tune, just look for the power band, that will determine your redline. Higher is not always better. On my tC, it quits making power at 5800, so there's no need to set a super high redline on it.
Porting and polishing you head does not change your max redline. Based upon your dyno sheet & the barber's dyno sheet our engines make max HP @ 6000rpm and start to loose power beyond 6500rpm. The reason is the camshaft specs specifically duration. IMO you do not need to be anywhere near 7200rpm. IMO 6500rpm should be you redline.
cdydjded is offline   Reply With Quote
1NZFE K1 by Carrillo Rod interest list xBoosted Forced Induction Forum 20 01-20-2009 03:51 PM
EVERYONE PLEASE STAY SAFE! Shroomster Off-topic / Other Cars / Everything else Discussions 5 01-01-2009 06:47 AM
CEL blinking during rev limit hit. ddongbap General Yaris / Vitz Discussion 2 10-01-2007 03:10 AM
Hyper Rev: Vol# 108 Vitz (No. 3) **IN STOCK & READY TO SHIP** KamiSpeed Sponsors Classifieds Area 1 03-03-2007 02:50 PM
