#1 | ||
![]() ![]() Drives: Yaris TS 1,8L Join Date: Oct 2008
But how on earth should I reach that A30 connector from engine bay. I have no place to go to take a look from underneath. By that picture you provided, I'm not sure it's even visible without taking at least the battery out. Quote:
#2 | |
It's definitely not an easy place to get to. And, unfortunately, the only place it routes through is one of the connectors at the top of the dash, which would require removing the dash to get to. I have a feeling that you will find that the pin on connector A30 is empty on cars that don't have the switch. So, you would need to add the pin (Toyota Part Number: 82998-24250) |
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 02:20 AM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 10:22 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 05:11 PM |
