![]() ![]() Drives: Yaris TS 1,8L Join Date: Oct 2008
Well then, this will have to wait until I find a way to get to that connector.
Or if someone else if willing to take a look at that A30 connector, and take a picture or two. Maybe even try to ground it with a piece of wire to do a quick test :) There is just one thing that is bugging me in post http://www.yarisworld.com/forums/sho...2&postcount=23 "automatic TRAC on...if vehicle speed increases" So what. We disable TRAC and push the pedal in "drag race" and it reactivates? That's just wrong :( |
#2 | |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
if you do it with a switch, it will. if you are drag racing and use a switch, it will reactivate well after launch you should be past the point of spinning anyway |
| DIY - Bypassing Tire Pressure Warning System (TPWS / TPMS) | CTScott | DIY / Maintenance / Service | 221 | 07-16-2025 02:20 AM |
| Cruise control install 2009 Yaris 3 door | PeteZNY | DIY / Maintenance / Service | 125 | 03-31-2024 10:22 AM |
| DIY - Headlights off with the Ignition Switch | CTScott | DIY / Maintenance / Service | 46 | 11-03-2018 09:42 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| replacement fog light switch? | yrsdrgn | Cosmetic Modifications (Exterior/Interior) | 4 | 07-17-2007 05:11 PM |
