Old 01-12-2017, 09:54 PM   #1
colindoling
Drives: 2008 Yaris Sedan
What type of kit did you buy?
i bought a rostra kit
colindoling is offline   Reply With Quote
Old 01-05-2017, 09:28 PM   #2
max924
Drives: 2010 Yaris Sedan
Hi Scott, I have a 2010 Yaris sedan with manual trans, pwr windows/locks and ac. Can you send me the list of parts required for the cruise control and pricing?
I tried sending a pm and it did not seem to work so just posting here...
Thanks!
Max
max924 is offline   Reply With Quote
Old 01-11-2017, 04:56 PM   #3
pribek
Drives: Man
Send a message via ICQ to pribek Send a message via AIM to pribek Send a message via Yahoo to pribek
Hi Scott, I have a Yaris 2016 Hybrid with AT and TSS . The car is for European market (Croatia).
If it helps I can send VIN number.
Sorry for my bad english
pribek is offline   Reply With Quote
Old 01-20-2017, 04:14 PM   #4
jra
Drives: 2015 yaris L
I bought a cruise kit from CT Scott about a year ago for my French built, 2015 Yaris L automatic, Took about 45 minutes to install, plug and play. Looks like it was installed at the factory and still works great.
jra is offline   Reply With Quote
Old 01-22-2017, 09:48 PM   #5
nvfool
Drives: 2012 sedan
2012 Yaris cruise control
I would like to get a kit for a 2012 sedan. Thank you
nvfool is offline   Reply With Quote
Old 01-28-2017, 11:39 PM   #6
jra
nvfool, when I ordered my cruse from scott, I had to send him a personal message to place order. I don't remember how I done that, clicked on his name in one of his posts or clicked on the quick reply in corner of one of his posts?
Old 03-27-2017, 10:18 PM   #7
Daemynz
Drives: 2010 Toyota Yaris
I apologize if this has been asked before but here goes.
I have a 2010 Yaris Sedan with auto transmission and no power locks or doors.
So for the OEM stalk route, do I just need the cruise control stalk and wire? Or do I also need the ECM connector pin?
Will probably just go ahead and use the steering wheel cover with the hole already in it too.
Cheers
Edit: Looked around a good bit more and looks like I just need the stalk :)
Daemynz is offline   Reply With Quote
Old 07-22-2017, 04:37 PM   #8
mumairr
Drives: Toyota Vitz 2010
My Vitz 2010 model Japanese imported. It already has wiring upto ECM (saw it by removing the cover behind the steering )but my cluster doesn't have any indicators for CC. Do you think if i install OEM CC, my car would be able to handle it? irrespective of the indication on the cluster? if this is the case, i might change my insturmenet cluster.
mumairr is offline   Reply With Quote
Old 11-09-2017, 11:05 PM   #9
Dohsh77
Drives: Yaris
Please
Can you tell my your car engine 1300cc or 1500cc
And what the part number of youe ecu
Please tell my
I want buy ecu to install cruise control
I bought one and it work good but ecu for 1500 cc so i have transimation problem
My e mail
Dohsh77@yahoo.com
Dohsh77 is offline   Reply With Quote
Old 11-09-2017, 11:07 PM   #10
Dohsh77
Drives: Yaris
I need ecu part number for yaris sedan1300 cc ATM old shap
That support cruise control
Old 11-10-2017, 04:50 PM   #11
weltall900
Drives: 2007 Toyota Yaris
My apologies if this has been asked before. I'm going to attempt this project for my wife's car. I'm not super mechanical, but I'm going to try my best and pray that I don't mess up her car! She has a 2007 Yaris with automatic transmission. I'm wanting to use the OEM stalk setup and I've read through much of this thread and the 2006-2011 Yaris – OEM Cruise Control Installation PDF. However, I'm not sure if her car is Sedan with power OR Sedan without power. Not even sure what that means. She has power locks, power windows, manual seats, automatic transmission, manual side view mirrors, and obviously no cruise control. I included an image from the guide here. Which applies to me? The one I circled in RED or the one I circled in BLUE
weltall900 is offline   Reply With Quote
Old 05-20-2018, 12:35 PM   #12
laobo
Drives: yaris sedan 2011
who said me know
dear!
w/power and w/out power means?
different?
laobo is offline   Reply With Quote
Old 03-14-2018, 07:28 AM   #13
Dohsh77
Drives: Yaris
All this ecu p/n for 1nz engine 1500cc. Any ecu p/n for 2nz 1300 cc
Old 04-29-2018, 05:24 PM   #14
DanielNorrisII@Gmail.com
2007 Toyota Yaris with Blue and Brown Wire in D3
I have a 2007 Toyota Yaris with Blue and Brown Wire in D3 no A21 pin 40. What am I supposed to do with wire coming from ECM A21 pin 40?
DanielNorrisII@Gmail.com is offline   Reply With Quote
Old 04-29-2018, 06:18 PM   #15
Ok, I looked up the electrical drawings for cruise control. D3 goes to AD4, which is a connection between harnesses, and on the other side of the harness connection their is no wire coming out to pin 40 on A21. I got extra repair terminals, so I will put a terminal in the empty side going to pin 40 and solder it to the repair terminal I install in pin 40.
Old 05-13-2018, 09:35 AM   #16
Prakersa
Drives: Yaris
Can you share the diagram of CC. Still curious for the AD4 location... Tks
Prakersa is offline   Reply With Quote
Old 04-29-2018, 05:30 PM   #17
Also, where can I get a Cruise Control Indicator Module? Does CTScott still have some available or is their a wiring diagram that I could build one myself?
Old 09-24-2019, 03:12 PM   #18
giorgos01
Drives: toyota yaris 06 1.3
ABOUT MY YARIS 2006 CRUISE CONTROL
HI CTScott
15 days ago i bought a 2006 gasoline 1.3 i really want to install cc and i would like your help, the car is european and my ecm number is
89661-0D310
https://photos.app.goo.gl/qqk757aZasRFupdj7
giorgos01 is offline   Reply With Quote
Cruise Control chessclubloser DIY / Maintenance / Service 11 03-27-2010 12:59 PM
Using Cruise control Driver General Yaris / Vitz Discussion 14 11-09-2006 11:12 PM
