Half a Bubble Off Plumb
That may be the source of the rumor, but a "heavy duty heater" isn't an electric heater.
![]() ![]() Drives: Black 5-Spd Sedan S Join Date: Aug 2009
That's what I had figured after going through a winter with no signs of electric heat. Is it a bigger heater core then?
![]() ![]() ![]() Drives: 2008 Yaris Sedan Join Date: Feb 2010
I'd been assuming that evidence existed. But... a quick search doesn't turn anything up. I've heard that it's a ceramic heater. (Makes sense.) But a search of the FSM PDFs for "ceramic" doesn't return anything relevant. Neither does a search for "heater". Then again, I'm finding that the the FSM is more concerned about the acceptable pulse-width of the signal from the wiper speed sensor than it is about... you know... things that are actually, physically important for the functioning of the car. Things made out of metal rather than silicon. Like pistons, brake rotors, and heater cores.
The utility of an auxiiary electric ceramic heater is dubious. If you look around at various highway travel stops (e.g. Love's) you can find 12v, 15 amp electric heaters that plug into the 12v outlet. They draw between 150 and 200 watts, and are fairly inexpensive. So you can easily judge for yourself. They put out a *barely* perceptible stream of sorta warm air. If the Cold Weather Package built-in version drew 50 amps(!), that would be about 700 watts at 14 volts and *might* make a slight difference. (And why are we still using 12v electrical systems in the year 2010, I wonder?) -Steve |
![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Mar 2010
I love seeing a yaris fully loaded with people, especially the hatchbacks. Speaking of such, I tried searching for it already but couldn't find anything.
So is there a thread with photo's of people squeezing into their yaris? I think it could be interesting and funny at the same time. |
![]() Drives: '08 Yaris LB 5M Join Date: Nov 2008
This isn't legal proof, but it's there if you have the 'All Weather Package'. The factory manuals (I have them) cover it extensively. I have seen that my Base Yaris with 'All Weather Package' has the special AC computer with the extra connector. It's additional power wiring for the PTC heater element. From a Yaris perspective it does draw a prodigious amount of current when active. It's only active when the heat is set to max, the blower fan is on, the engine coolant is < 150F, and ambient temps are below 50F. You can see it's effect on system voltage with a Scangauge.
Search for 'How does a PTC heater work?' and you'll stop expecting to smell it or overtly feel it. It just speeds up the warming. I can definitely tell it does that where I live. |
Cool! (Or warm, I guess.) Thanks for that info.
Aha! "PTC" is the magic search term. I was searching for "ceramic" earlier. It appears that it has three settings and two associated fuses, a 30A and a 40A. The schematic they give makes it difficult to tell what's happening. But I think that it might have a setting to pull through both fuses simultaneously (two separate circuits in the unit) for a total (upper limit) of 70A. At 14V, that works out to nearly 1000W, which puts it in league with the low setting on most household ceramic heaters.
-Steve |
you see.. i wasn't all that crazy about the electric heater...
i'm not sure how there is a sensor that reads cabin temperature, but the < 150F coolant makes sense.. |
![]() ![]() Drives: 2 Yaris Hatchbacks Join Date: Dec 2006
About the PTC heater
In the US, the All Weather Pkg cars have the ceramic auxilliary PTC (Positive Temperature Cooeficient) heater. When does it kick in?
From the AC section of the manual: "When the PTC heater operating conditions are met (engine at idling speed or faster, ambient temperature is 10°C (50°F) or less, engine coolant temperature is 65°C (149°F) or less, and No. 3 heater control knob setting is MAX HOT), turn the blower switch to the Lo setting." Does my car have one? Look at the _AC_ _Amplifier_, a black box screwed under the main AC box behind the center console. (Put your head down by the pedals, look under the left side of the center console, pushing the carpet out of the way.) TWO connectors? You have the PTC heater. One? No you don't. All this info applies to 2007 spec US models, others I don't know. See selected pix from the online manual. (Sorry if it is clear as mud.) |
| heater control box issue | DevilGirl | DIY / Maintenance / Service | 12 | 01-08-2010 03:45 PM |
