#19 |
![]() ![]() ![]() Drives: 07 Meteorite Metallic Yaris LB Join Date: Jul 2006
The 1NZ-FE, as most Echo, xB, and xA tuners have found already, is a well tuned and robust little engine, its problems have always come from the poorly designed intake and exhaust portions bolted onto the engine, the factory designed pieces have always been restrictive, again, thats why header and properly designed intake will net quite a good gain with this engine, but there's only so much power to be freed up. As for internals, any pistons and rods designed for the xB, xA, and Echo should work. Just be glad we're not trying to tune a Versa here, from what I understand, with that MR18DE, tuning is pretty much impossible without a whole load of cash to back your efforts up, the computer runs the engine in a perpetual lean state.
#20 | |
CAI.. over $200 Header: over 200 catback exhaust, at least 500 omg i'm already at 900.. and i'm assuming most of y'all would have a "shop" do the work so yeah.. there's your grand. second.. horsepower numbers are not additive. WR claims 11hp.. i've dynoed CAI's that gave 2HP.. sorry, 11HP on a 1.5? it better have a fan on the end of it. anyway, if an exhaust claims 11hp and a intake claims 11hp and a header claims 11hp you cannot add those together and say, hey guys i'm making 33 more hp, cuz it said so on the box... oh and ZPI? lolol i wouldn't touch their products with a ten foot pole. the product has no image, and therefore does not yet exist. ZPI isn't exactly known for their "ability to act like adults" either, which makes me shy away from them. |
#21 | |
#22 |
![]() ![]() ![]() ![]() ![]() Drives: Yaris Sedan Join Date: Sep 2006
Bottom line this 1.5L motor isn't make for lots of HP... get the famouse 1.8L from early years(1980 +) motor stack some Webber carburator and 65HP of NOS and live happy
. And believe me those engines do have very very hard internals and potentials
I Drive a 129whp Yaris ;) |
#23 |
20valve 4AGE comes to mind or the 16V red hat 4AGE that went in the MR2's :D that engine revved happily to 8500rpm anytime i stepped on it
#24 |
Did someone say NOS?
I think we have a winner!
#25 |
NOS is pretty impractical and illegal for most real racing..
#26 |
i hope this will help some who are curious...
this is what i've spent and done concerning performance upgrades: 2007 Toyota Yaris Sedan S WeaponR Short Ram Air Intake - total costed me $410 CAD Megan Racing 4-1 Header- total $230 CAD Custom 2" Catback Exhaust w/ Dynomax Muffler - total $605 CAD Intake estimate around 10 hp gain } * Header estimate around 6 hp gain } * estimate!! correct me if u differ Exhaust estimate around 10 hp gain } * That's already an estimate 26 hp gain! almost 25% increase! Those upgrades only costed $1245 CAD and those prices includes shipping, bokerage fee (because i live in Canada), and even installation. Maybe with the other $2000, you could get rims, lowering springs, and the sustec strut bar from tanabe.. And last, with all these installed, the fuel economy improves quite noticeably! |
#27 | |
![]() ![]() ![]() ![]() Drives: 2007 Yaris Sedan "D" package Join Date: May 2006
#28 | |
Turbo Yaris
Drives: 07 PW Yaris Join Date: Dec 2006
As I have done my own investigation on the 1NZFE. Curious to know what you mean by "long" and side loading upon combustion. Care to go into detail? |
#29 |
i'll see if i can find it. EL prototypes disappeared recently but maybe someone archived it..
#30 |
it's gotta be more than 10hp!!! ill try and find a place to dyno.. if anybody know where I can get it done in Vancouver, BC, let me know!!
#31 |
![]() ![]() Drives: '00 s2000, 2007 yaris hatch Join Date: Jul 2006
I say you keep the money in a risk free account, such as bonds, money market accounts, or even a CD. Or you can buy my S2000 and rev it to 9k rpms all day long.
A |
#32 | |
Lets touch on the internals. First and foremost are the rods. Although quite strong for their size, they are designed for normal aspiration only. A half point higher in compression is about all they can handle daily without failure. Once boost is added to the equation, it becomes Russian roulette as to when they will let loose. You may last eight months with 50,000 miles or blow it the first pass down the street; there are no warning signs. We know this because of the testing of our turbo kit for the last year. The testing started on the Echo then was transferred to a Scion. The testing was controlled and only once was it taken past its set 7-psi mark while in our possession. Its one time high boost pass on the dyno was done to see how much the turbo would produce at maximum efficiency. Fueling and timing were changed to handle this. Every month the pan was dropped and there were no signs of abnormal rod bearing wear. The compression was straight across the board every time. The first motor lasted 6 months with about 35,000 miles. Its life was cut short while at the paint shop. Rumors placed it at the local street races near the paint shop, which they had for 3 weeks. All the baked on rubber in the fender well was the first clue. It let loose on its way back from them. A fresh motor was installed ASAP to continue the testing. The old motor was broke down to find the rod broke right above the crank pin. The dangling rod was beaten into the walls and punctured holes on both sides of the block. The second one let loose 12,467 miles later. It had seen one race with 3 passes at 9 psi. Fueling and timing were also changed to handle this. Other than that it was daily driven. The rods let go again, the same way, only this time it punctured the water jacket and destroyed the head. These engines have the crankshaft offset 12mm to the thrust side of the cylinder bore centerline. This reduces the side force generated at maximum compression, for reduced friction and improved fuel economy. Toyota calculates the offset crankshaft configuration reduces fuel consumption by between one and three percent. Unfortunately, this throws the angle of the rod way out on its upward travel causing the rod to just give up under boost and snap. If there is any detonation or pre-ignition this breakage will occur at an accelerated rate. The movement and breakage of the cylinder walls is the same as Honda’s open deck. Although we have yet to split one, we designed a block guard just in case. This product keeps cylinders from moving around and from splitting open the top of the bore. We are currently designing a forged replacement rod as well as a rod piston combo for high boost applications. The first of the sleeved blocks is being tested now. Now for the ecu. It cannot handle boost in its stock form. Its timing is set for the stock parameters only. It will not handle larger injectors either. Piggyback or stand-alone management is needed to fuel the turbo properly, end of story. From what we have seen, these issues probably were found by the likes of Blitz and Greddy long before we did. That’s why the boost on their kits was so low. The stock injectors will supply enough fuel for 3 to 4 psi if the MAF reaches full voltage and gets the injectors to 85 percent duty. Unfortunately you end up with a 15:1 AFR at peak rpm this way. Good for passing emissions but bad for the motor. The RS turbo Vitz has an ecu calibrated for the larger injectors that feed 150 ps at the flywheel which in turn is 127 ps at the wheels. The blitz s/c was turning 122 hp to the wheels without an ecu for the US market. With the ecu (JDM only), the s/c put down 129 ps to the wheels. It seems like the kits are limited to 150 at the flywheel but no one says how long it will last. Our turbo kit produced 144 hp and 150 tq to the wheels. That’s 170 hp at the flywheel. We have worked with several management systems and we will inform the public of the best one for our kit. We will release our kit soon but cannot warranty it except for workmanship. This kit will push your engine over the edge in the long run but if you build it our kit will be able to provide up to 250 hp at the flywheel. That’s 217 at the wheels. With all this said, it is up to you, the consumer, to decide whether this kit is right for you. Copyright © 2004 E.L. Prototypes Last modified: 01/11/05 |
#33 |
![]() ![]() Drives: Black Liftback Join Date: Aug 2006
good read
Well if it’s not a hybrid how do you get such good mileage? |
#34 |
where in miami are you? i'd love to talk to you in person
#35 | |
![]() Drives: Nissan NX2000 Join Date: Nov 2006
There is a limit to how much power can be gained by simple bolt-ons. For example, look at the Megan header. The primary tubes are almost identical in length to the stock design, and are far too short to be optimized for this engine's powerband. Once again, you will be limited to how much power you can pick up from enlarging the primaries and cleaning up the flange and collector area. Has anyone ever tried porting these areas of a stock header? The Celica GTS guys do this and have found gains comparable to aftermarket headers. Also, take manufacturers' dyno charts with a grain of salt. It is very easy to manipulate the dyno results to your advantage, for example by picking the worst 'before' run and the best 'after' run. |
#36 |
+1!!!
