Roadrunner Jr.
What is the contrast between this one and the I6SW?
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine |
I'm guessing...
Sensitivity and Mounting Dept. (about an inch more for the JL) JL Audio 6W3v3-4 80.49 dB at 1 watt I6SW 90 dB at 2.83 volts/1meter My translation would be the JL is not as efficient as the I6SW and needs a lot more power. Please add and/or correct me if I'm wrong. D.
. CLA 250, 4MATIC |
I took out the Camber kit, no more uneven wear on the rear tires.
Uneven wear on tires produces lots of noise and if too much some vibrations. I'm was able to squeeze the rubber rings a little bit more into the springs, this increases the spring rate and without a sub-woofer box in the trunk, the Yaris handles much better. D.
. CLA 250, 4MATIC |
Roadrunner Jr.
You're looking at about 87-88 dB at 1W/1M on the Imagine. So essentially it'd be more than twice as loud (edging closer to three times) given that it's the same general cone area. I'd estimate that the I6SW is not only cheaper but it can fit into the same sealed enclosure and go ported and bandpass (not that you have to worry about the latter). The XMAX on the JL is 1mm more but given the difference in sensitivity, that JL still won't stand a chance.
#5 | |
did you have a chance to ask Jim and order a I6SW? should I call him tomorrow? D.
. CLA 250, 4MATIC |
Roadrunner Jr.
I'm not going to see Jim until Wednesday night.
I would call him tomorrow, yes. Mention that you'd like to order the Hybrid I6SW and have him make a nice trim ring for it, all flushed and everything. With the being said, would you mind if we made some video of it? I would like to give it some break in time in our sound room for a night. Perhaps even put it in a small sealed enclosure and, like I mentioned, shoot some video of it in action. Thoughts?
#7 | |
PS. I called Jim, I told him I wanted an I6SW and he was going to call me back. D.
. CLA 250, 4MATIC Last edited by derickveliz2; 03-23-2011 at 01:10 AM. |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
Hey SQ, Whats your thoughts on Eric and Matt leaving ID ? Any ideas on Eric's next project?
Roadrunner Jr.
Well...apparently Eric couldn't get the other major partner to sell to him. I'm not quite sure of Matt's connection.
I know the shop is already liquidating the ID stuff. I'm also hearing that the rights to the compression horns are leaving ID as well...That doesn't bode well.
He apparently has plans under way for his new "endeavor" and in no way is he giving up his love of sound. He stated on another site Matt is no longer with ID and is going to work with him. So basically, he may not own ID anymore,but he will resurface with a new "project". He seems to be a genuinely good guy and they wont keep him down. Never know, He may have had some new ideas that never came to light since he knew this was coming........
Roadrunner Jr.
It's too bad, I know that Scott could probably use Matt on the development of his woofer line...
Roadrunner Jr.
God help me derick, I just picked up a bit one for the system.
OHHH NO!
what are you going to do now? D.
. CLA 250, 4MATIC |
#14 |
Roadrunner Jr.
...I'm going to have a full 1/3 octave EQ'ing on each speaker, twice as much T/A processing, and 48 dB slopes. There's more of course but, you get the point.
#15 |
right about then, i saw SQ doing this pelvic thrust thing and going ,"can ya feel it? huh? can ya feel it!!??" LOL
#16 |
Roadrunner Jr.
“To argue with a person who has renounced the use of reason is like administering medicine to the dead.” ― Thomas Paine Last edited by sqcomp; 03-24-2011 at 12:32 PM. |
#17 |
LMAO,Exactly right....
#18 |
Roadrunner Jr.
Hey D,
Got a neat little project going on with audio IN the house: ![]() ![]() ![]() ![]() One panel a night. I only have four bar clamps... :(
| sound deadening: sq footage amount for 3dr | goku87 | In Car Entertainment + Electronics (audio / video / alarm) | 29 | 11-14-2013 01:37 PM |
| 2007 Yaris S Sound Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 70 | 12-13-2010 08:40 PM |
| Sound deadening | 06vitzRS | General Yaris / Vitz Discussion | 10 | 05-05-2010 02:51 PM |
| Sedan Door Panel Deadening | sqcomp | In Car Entertainment + Electronics (audio / video / alarm) | 42 | 06-01-2009 03:47 PM |
