Old 03-04-2010, 09:21 AM   #11
Originally Posted by Focus_Sh1ft View Post
Alright so I used diodes, but no dice. The markers signal correctly when the parking lights are off, but when they're on the markers stay lit up: no signaling. I tried both of the two lower green wires but no difference. I'm not sure what to do now... the diode idea seemed flawless
Out of curiosity, what purpose does that black and white wire serve?
That makes sense. The diodes act like OR gates, so if either is on the LED will light. To have them still be able to flash when the parking lights are on is a bit more tricky.
What I would do is to add a resistor in line with the parking light wire. This will make the LEDs glow, but less brightly from the parking lights. Then, when the signals flash, the LEDs will pulse from dim to bright. For the resistor I would experiment with 1K, 5K and 10K to see which looks best.
The white/black wire is ground.
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 10:06 AM
Connecting wiring to small trailer charles nelson DIY / Maintenance / Service 8 04-24-2012 05:39 PM
Wiring Pictures MitchEvious In Car Entertainment + Electronics (audio / video / alarm) 2 12-28-2009 11:43 AM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 03:56 PM
Pioneer AVH-P4000DVD Wiring Adapter?? maxiMOOM In Car Entertainment + Electronics (audio / video / alarm) 2 02-11-2009 01:11 PM
