Old 03-29-2010, 08:37 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
I would try using meguires ultimate compound. Only product you will need. I would advise using 1 inch thick microfiber applicator to avoid putting in heavy scratches from your fingers. When you apply it, it will sort of feel like its gliding across the paint as you start to work the product you will feel a slight resistance that is when you know the product is working. At that point you want to use moderate pressure. Try one spot first. Then take a microfiber cloth and buff out the residue and check your work. Then repeat as nessisary. That way you can gauge how much you have to work the product in. You dont want to take more clear coat off than nessisary.
