Old 03-30-2010, 09:49 PM   #1
yarrr
Drives: 07 sedan
Originally Posted by RHDVIPbB View Post
Went in today after seeing this and they have to order the part
They have to order a zip tie? lol
yarrr is offline   Reply With Quote
Old 03-30-2010, 11:52 PM   #2
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
No apparently it was something else. Hopefully a new bracket. I can't speak for other dealerships, but the tech guys at mine are very thorough. It also helps that some of them I went to school with.
Old 04-17-2010, 09:15 PM   #3
Billiam
Drives: '10 White Yaris 4D LB
Hmm...noticed that I sometimes get a similar rattle in reverse. Not everytime though. I'll have to get up under her tomorrow and check it out. I wonder if I have to use an "OEM Toyota" ziptie?
Old 10-08-2010, 02:33 PM   #4
aaronwer
Drives: 2007 Yaris Sedan
hey everyone I have a 2007 sedan and experience the same problem when in reverse. I'll try the ziptie method and see what happens.
However, there is another rattle i'm experiencing (surprise surprise). When the fan comes on and runs while idleing in park (or at a light while in drive) the vibration causes the hood to rattle against the part of the car it rests against while closed. I verified this by having my wife put the car in drive while holding the brake. When I put my hand on the hood, the noise stops.
I'm guessing this has to do with the fact that there is not much padding along the edges of the hood. Any ideas to absorb the vibration and stop the rattle? a sticky foam piece of some kind?
aaronwer is offline   Reply With Quote
Old 01-10-2011, 05:44 PM   #5
frog13
Tw200--excellent!
Drives: 2010 yaris..absolutely red.
aaronwer....try tightening the latch bolts.
Also have the same rattle that most folks are describing....when in reverse at a standstill....will inspect the engine area and see if it IS the same problem...thanks for the heads up yaris world crew!!!!.
frog13 is offline   Reply With Quote
finally found the 5w-20 TSB... static808 DIY / Maintenance / Service 97 01-02-2013 06:28 AM
Toronto Canada meet June 16th second part of the day photos Ric n Sov's Vitz RS Photo-Video-Media Gallery 23 06-20-2007 01:22 PM
TSB for steering pull? vst DIY / Maintenance / Service 12 06-09-2007 02:40 PM
My New Yaris (First Car), About me, and my TSB Questions dlinkwit27 DIY / Maintenance / Service 1 06-03-2007 12:34 PM
Rattle fixed! Bretsuaz DIY / Maintenance / Service 32 03-30-2007 08:39 PM
