Old 01-04-2007, 04:49 PM   #1
barryware
Actually... When the front defroster is on you MUST use outside air, not recirculated (I know that has been covered). I crack open a side window just a bit also which helps a lot.
My 07 liftback has three knobs in the middle. Top is fan speed, outside of the fan speed knob is the fresh air / recirculate selector, center knob is the selector knob for where you want the air to come from, and bottom is your temp setting.
If you look closely at the center knob, it has a little graphic near the defrost selection telling you to use the fresh air selection for defrosting / defogging.
There is also a button in the center of the middle knob that allows you to turn on or off the AC compressor. The compressor does not have to run all the time.
I have a scan gauge connected which gives the actual engine temperature, not just the Cool / Hot light.
If it is cold out, it takes quite a bit of time for the engine to get over 150F or so ESPECIALLY if you have your heater fan set faster than 1. At a red light, if you turn the fan up to 3, you will actually start cooling down the engine. I don't know what happens to the temperature if you use 4. 3 scared me.
If you want your engine to warm up faster, leave the fan speed on 1 for a while. Not a lot of heat creating horsepower under the hood.
barryware is offline   Reply With Quote
Old 01-04-2007, 06:30 PM   #2
Racer X-8
Races Little Red Wagons
Racer X-8's Avatar
Drives: red '07 Yaris liftback auto.
Originally Posted by barryware View Post
Actually... When the front defroster is on you MUST use outside air, not recirculated (I know that has been covered). I crack open a side window just a bit also which helps a lot... ...If you look closely at the center knob, it has a little graphic near the defrost selection telling you to use the fresh air selection for defrosting / defogging...
There's nothing to keep you from running the defroster with recirculated air. The fresh / recirculate selector just flip-flops a flap mechanically and there's no interlock or anything to keep you from flopping it over to recirculate while you have it set on defrost. I know for sure because I was just a minute ago filp-flopping it back and forth while it was blowing in the defrost position. Air came out of the defrost ducts at the windshield, nomatter whatever the fresh / recirculate selector was doing.
And, the graphic is just that - it's a graphic. It's recommending to you what to do, just a recommendation...
...There is also a button in the center of the middle knob that allows you to turn on or off the AC compressor. The compressor does not have to run all the time...
I was also making sure that the AC stays on when you have it blowing in either of the two defrost positions. It does not matter what you do with the AC pushbutton with the little *green* light - the AC stays on while defrosting. I had the hood up and I could hear the compressor turning on and off. It stays on in the defrost positions nomatter what you do with the AC pushbutton.
Sorry I had to disagree, just stating the facts.
edited-out the *blue* color from my mind's eye. That's one for you there, barryware hehehe...
Racer X-8 is offline   Reply With Quote
Old 01-04-2007, 08:08 PM   #3
barryware
I was also making sure that the AC stays on when you have it blowing in either of the two defrost positions. It does not matter what you do with the AC pushbutton with the little blue light - the AC stays on while defrosting. I had the hood up and I could hear the compressor turning on and off. It stays on in the defrost positions nomatter what you do with the AC pushbutton.
I understand that you don't HAVE to do anything. You can run your defroster anyway you want. Next time it is cold and rainy or snowy out, set you heater for recirculate.. It will only take a couple of minutes for you windows to start fogging up. It has to do with dew point which is directly related to moisture content and temperature of the air. That's why they "recommend" to use the fresh air setting.
As far as the compresser goes... No, it does not run automatically when in defrost. That is a fact at least on mine. I have had to turn it on manually on the 50 degree days when it is raining out. My light is green, not blue. Maybe the blue light models are automatic. If it is cold enough out, it won't run even with the switch on. The low pressure side if the refrigeration circuits pressure is too low to allow the compressor to run. That's why the compressor "cycles". When the low pressure reaches a certain temp (pressure in this case as they are directly related), the compressor "cuts out". When the low pressure sides pressure rises to a given pressure, the compressor "cuts in".
So There!
My Yaris is red... Red is the fastest color!
Old 01-04-2007, 08:47 PM   #4
Racer X-8
Racer X-8's Avatar
... My light is green, not blue...
Aw crap! You got me there! Mine's green too (had to go out there to make sure). Shoot. When did they stop using blue? Oh! Well! . . . You win
About your AC compressor cycling, if I read your bantering correctly, you need to have it checked - seems like it needs a re-charge of freon.
Oh, and, yes, red IS the fastest color. It adds at least 10hp to your car. Oh, yeah!!!
Old 01-04-2007, 10:57 PM   #5
barryware
Dude... I didn't mean to "banter". I would usually let it go. But..... You are wrong telling me I am wrong.
I am a certified, registered, licensed, type III universal refrigeration technician.
I may not know anything about refrigeration but I have seen it a couple of times on TV.
Automobile AC system do "cycle". The compressor turns on and off via low side pressure. Keeps the evaporator from freezing and the high pressure under control in the extremes of an automobile application.
AC in a car is exposed to conditions that a home AC system or your refrigerator will never see. They will cut out on high pressure too but only as a safety measure. It is the low side pressure switch that regulates the evaporator temperature.
Point is... That a cycling automobile AC application is completely normal and does not mean that the system needs freon. According to what I have seen on TV
With that said.... Lets not forget that I am also the guy that over filled the crankcase on my first oil change... Oops
