Old 04-06-2010, 07:09 PM   #1
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
Infinity refrence 6.5 components... can find them online for cheap... around $100 for a pair. Regardless of what you go with, make sure you buy a pair of components & spend more than $80 online, or $150 in store. Stay away from co-axials/tri-axial/quad-axials... you only need 1 tweet per speaker, having 5 doesn't help sound quality.... if anything it makes things worse, but it does look good for the marketing department, and allows a company to charge more.
Old 04-06-2010, 11:49 PM   #2
IsLNdbOi
IsLNdbOi's Avatar
The Yaris is a noisy car. There's pretty much no sound-proofing put into it at the factory so I can accept not having crystal clear sound.
I just want more "definable" lows and mids. The JVC AVX77's setting allow me to get decent highs w/ just the stock speakers, but the middle and lower end is a little lacking, even w/ the 10" sub. and the high-pass filter turned off in the AVX77's menu.
So far, I see recommendations for Infinity Reference, Alpine Type S, and Hifonics. People on another forum are recommending Polk DBs.
I wish I could try them all to see which of them will give me the additional mids. and lows I'm looking for just by running them through the HU and not an additional amp..
Old 04-07-2010, 12:27 AM   #3
_S7V7N_
_S7V7N_'s Avatar
Drives: Yaris 4 Door Sedan
Good Luck bro, You're in for hours of research, and tons of information, Loll trust me i did hours and hours of research and searching till i just said " ta hell with it " and got My speakers. Let us know which route you go and if you're satisfied with your choice when you finally do choose.
Old 04-07-2010, 11:52 AM   #4
talnlnky
Audio Junky
talnlnky's Avatar
Drives: 08 liftback
it's really hard to compare speakers. Even if you can track down a pair of each kind, if you don't listen to them in a car, installed they way you will have them installed, you might not be getting a realistic audition of them. In stores they are often installed in 1cuft sealed boxes which will give a different sound than if they were installed Infinite Bafffle in a car door. And they are also positioned better in the store walls too.
I would focus mostly on the tweeter aspect, there are few things worse than buying a pair of speakers with a tweeter that you just don't like. I personally stay away from most metalic tweeters because to me they sound to harsh/shrill usually. Other people love them.
As for the lower end midrange/midbass.... the speaker that is the least efficient, or has the smallest magnet will most likely be the speaker that has the most potential for the lower notes.... but these are generalizations. There are trade offs in speakers, and when it comes to low notes your options are small box, extended low range, or high efficiency. You can pick one or two, but you can't have a speaker that is good at all three. For door speakers we can pretty much build a speaker for a large box, and focus on the efficiency & low range.... however that is not always what the manufacturers do.
Old 04-07-2010, 12:07 PM   #5
IsLNdbOi
IsLNdbOi's Avatar
I guess I should get speakers then that have good mids and lows since I can always add tweeters later on.
Old 04-16-2010, 09:01 PM   #6
Malifabian
Malifabian's Avatar
Drives: Yaris Sedan 2008
I got some infinity speaker that were under a hundred for the pair at Best Buy.
Malifabian is offline   Reply With Quote
Old 04-17-2010, 02:03 AM   #7
IsLNdbOi
IsLNdbOi's Avatar
Ok, so they were under $100. Do they fit any of the other criteria I'm looking for (mentioned in my various posts above)?
Old 04-17-2010, 05:13 PM   #8
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
If you have a SUB, don't try to make your other speakers play BASS.
It will only muddy them up at louder volumes.
Let the drivers reproduce the frequencies they were designed for.
If you are running low-watt deck power, you need a cheap efficient speaker.
Don't buy 100watt component speakers, those need more power than a deck puts out.
Try THESE:
http://www.sonicelectronix.com/item_...TS-G1643R.html
They sound nice on deck power, and they are CHEAP.
But as I said, don't expect them to play any BASS. Use your SUB for that.
Old 04-17-2010, 05:33 PM   #9
IsLNdbOi
IsLNdbOi's Avatar
Please read my posts above.
Yaris sedan low and high beam jorizk DIY / Maintenance / Service 10 03-02-2010 09:49 AM
Needed high quality speaker adaptors for 6.5 and 6x9 for sedan YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 7 09-27-2009 02:43 PM
High quality coilovers avaialble for Yaris? echosqwat Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 09-09-2009 06:27 PM
Change to high quality filter lead to drastic drop in fuel efficiency lh59 DIY / Maintenance / Service 19 07-02-2009 02:22 PM
What do you guys think of this high quality hubcap YarisSedan Cosmetic Modifications (Exterior/Interior) 18 01-15-2009 04:34 PM
