#19 |
Drives: '10 Yaris5drHB+99 4runner LTD Join Date: Sep 2009
well, 'any old' ziptie may crack, rot, break, not do the job, cut into the housing
a Toyota spec ziptie will just plain work. the difference between walmart zipties and a good one can be huge |
#20 | |
![]() I do have some ties that are designed for use in hot conditions and are UV rated. Might as well use one of those. |
#21 |
Right beside you, wave
Drives: 08 PBM Yaris Sedan Join Date: Oct 2008
Well I got mine fixed and it doesn't rattle now. I asked the guy what was replaced or what part he needed and apparently there is a bracket that was redesigned to prevent the cable rubbing.
![]() 2008 Toyota Yaris Sedan. Pacific Blue Mica. Custom vinyl eyebrows, color matched interior trim pieces, Vios lip spoiler, 17" Maas rims 2010 Scion xB 7.0 Release Series. 1535 of 2000. Murasaki. Stock with TRD springs. |
#22 |
Despite being an '10...mine had this issue sometimes. Went out this morning and did the ol' ziptie.....problem solved.
Now I just hope Toyota doesn't void the warranty for using an aftermarket tie.
#23 |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
I noticed this noise on mine 2010 LB the other day but didn't think too much about it until I found this thread. I just went out and popped my hood and my cable is just resting against the bracket. I will do the old zip tie fix tomorrow at work myself. I can't help but to wonder what it would take to get my local dealership to fix it under warranty since the TSB only covers up to 2009 models.
#24 |
If you don't mind cold you pop your hood and see what was actually done to fix it? I am just curious to see if they used some form of zip tie or if they actually replaced a part. The bracket is easily visible from under the hood. thanks.
#25 |
![]() Drives: 2007 Yaris Sedan Join Date: Oct 2010
hey everyone I have a 2007 sedan and experience the same problem when in reverse. I'll try the ziptie method and see what happens.
However, there is another rattle i'm experiencing (surprise surprise). When the fan comes on and runs while idleing in park (or at a light while in drive) the vibration causes the hood to rattle against the part of the car it rests against while closed. I verified this by having my wife put the car in drive while holding the brake. When I put my hand on the hood, the noise stops. I'm guessing this has to do with the fact that there is not much padding along the edges of the hood. Any ideas to absorb the vibration and stop the rattle? a sticky foam piece of some kind? |
#26 |
Tw200--excellent!
Drives: 2010 yaris..absolutely red. Join Date: Jun 2010
aaronwer....try tightening the latch bolts.
Also have the same rattle that most folks are describing....when in reverse at a standstill....will inspect the engine area and see if it IS the same problem...thanks for the heads up yaris world crew!!!!. |
#27 |
![]() ![]() ![]() Drives: '08 Blazing Blue Yaris LB Join Date: Sep 2009
regular zip works for mine.
#28 |
TURBO MUTT
Drives: 2007 Toyota Yaris 4dr Hatch Join Date: Oct 2013
Here is a picture! HELP
Here I zip tied what i thought was the shift cable i really hope i am wrong as the rattle did not stop! Can any one point out the cable or upload a pcture please
Yaris.jpg |
#29 |
That is the cable. Check the exhaust heat shield as well, as the cable travels along it, and if any of the mounting screws have pulled through the aluminum it will rattle.
#30 |
Drives: Toyota Yaris 2009 Join Date: Jan 2014
Rattle be gone.
The information in this thread is awesome.When it gets warmer I will get rid of the rattle.Thanks for the info.
#31 |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
I checked mine and the shift cable was under the wire support and unattached. Close to the exhaust. Is yours like that as well?
I think it makes more sense for the cable to be installed above the bracket, so the support would pull it away from exhaust. I could not move it enough and just zip tied it below the wire support. The access from above the engine was very tight. Does it look like it's correct now?
#32 | |
#33 |
Thanks! There is still some knocking/rattling sound in reverse especially on cold engine. Maybe from somewhere else?
#34 |
![]() Drives: 2008 Toyota Yaris 2D Join Date: Apr 2014
Anyone have a picture of what this looks like from above? I'd rather try to it without jacking the car up.
Also, if i do have to jack the car up, because its too low to crawl under it, where are safe points to use jack stands? |
#35 |
#36 |
| finally found the 5w-20 TSB... | static808 | DIY / Maintenance / Service | 97 | 01-02-2013 06:28 AM |
| Toronto Canada meet June 16th second part of the day photos | Ric n Sov's Vitz RS | Photo-Video-Media Gallery | 23 | 06-20-2007 01:22 PM |
| TSB for steering pull? | vst | DIY / Maintenance / Service | 12 | 06-09-2007 02:40 PM |
| My New Yaris (First Car), About me, and my TSB Questions | dlinkwit27 | DIY / Maintenance / Service | 1 | 06-03-2007 12:34 PM |
| Rattle fixed! | Bretsuaz | DIY / Maintenance / Service | 32 | 03-30-2007 08:39 PM |
