CTScott has a Techstream. It is not programable, he has tried. Techstream is only meant to reflash the ECU via Toyota TSB's. The reflash cannot be customized. That being said I still want you H3LlIon to try what you can to find a solution. A week ago I found out about the Techstream Lite & spoke to Techstream in detail about this issue.
As for the Dezod in Line ECU, a week ago I spoke to both Paul from Dezod & Allan from APR about their unit. They have no intention to make a unit for the Yaris, it is not financially feasible for them. But Paul did say that if I do the leg work in getting some technical specs on the Yaris ECU, he might change his mind. Iv have been working on that for him.
The issue is going to be the cost which will be in the $1800-$2000 price range or more. Now I know thats alot of $$$$ & it is not for everyone. This is not going to be for the N/A guy. This is a unit that will be for turbo or S/C. It will be comparable to a AEM EMS. It would be 100% better than a AEM FIC or Emanage. It would be a plug and play unit.
