Old 06-02-2011, 01:19 PM   #1
CtrlAltDefeat
I ♥ Yaris
CtrlAltDefeat's Avatar
No, cold denser air helps mpg. For simplicity's sake lets say you need x amount of hp to maintain whatever speed. With hot air, the engine has to use less fuel per stroke, because the lower oxygen level but in order for the engine to output the proper hp and maintain the speed, the rpm has to go up. With the higher rpm being used to maintain the same speed, the hotter air gets worse mpg. Sure it uses micro-grams less fuel per stroke per cyl with the hot air, but every single additional rotation that it has to use to maintain hp uses an additional unit of fuel in each cyl...
Old 06-02-2011, 04:21 PM   #2
rningonfumes
rningonfumes's Avatar
Drives: Yaris Sedan 5MT
The RPM is related for the most part to the gear and the speed you're at. Most of us see the best mileages over the summer months. And this is even with the gas ratio changes some states are required to do.
When you get cold air, the computer has to compensate for the denser air...meaning more fuel to keep it at the ratio the computer thinks it's supposed to be.
If you want more power, sure take in colder air but that is not the route for getting better mileage.
Old 06-03-2011, 11:07 PM   #3
joe keeney
Drives: yaris 2 door hatch
texas wide open 75 mph most of the time. I average 36 mpg this car made to drive.
joe keeney is offline   Reply With Quote
Old 07-21-2013, 07:00 AM   #4
ldinkinsjr
Drives: 2009 toyota yaris sedan
when I first bought the yaris 09 i got 32-33 MPG, mixed driving around 75-80 MPH. Then I put an AFE dry cold air intake on, inflated my tires to 40 psi and got 33-37 MPG doing 75-80 MPH, I changed my oil to amsoil, 5w30 with high efficiency oil filter and got 37-39.5 MPG, then I changed my transmission fluid to amsoil, and got 42.8 MPG. So I tried to slow it down and let off the accelerator as much as possible, driving between 55-65 MPH and shot up to 48.9 MPG thats with the original tires (88000 miles) just got new Defender 185/60-15 tires on there now and hope my MPG dont drop any, hoping it gets better. My yaris is an AT.
ldinkinsjr is offline   Reply With Quote
Old 07-22-2013, 07:10 PM   #5
07liftback
07liftback's Avatar
Drives: 07 Yaris Liftback
Really good tips here. It almost sounds like an ad for amsoil but I've heard similar results in other threads. But to think that just by switching to amsoil, you've boosted your mpg by 30% is rather impressive.
With my 07 MT Yaris, I consistently get anywhere from 37-40mpg with 30% city driving and 70% highway. Depending on how fast I hit the highway, I can maintain a steady 38+ mpg usually. My hood is slightly up (long story) and someone stole my mirror cover so I know my aerodynamics are horrible. Not only that, I haven't washed the car in a few months...
My sister has the 10 AT Yaris and she tells me that she consistently gets low 30s 80% freeway in hers.
07liftback is offline   Reply With Quote
Old 07-22-2013, 01:47 PM   #6
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
^^ Hmmm... maybe I should do the amsoil things to my 09. I'm getting 30-32 consistently. About to turn in a 27 or 28 tank.
Edit: What "high efficiency filter"?
Edit edit: Just filled up, got a 27.6 mpg tank.
Old 07-22-2013, 01:54 PM   #7
Shinare
Shinare's Avatar
If I hadn't previously owned a 07 manual 3-door yaris I probably would be saying Yaris' were terrible at gas mileage. There's something wrong with my current one I'm guessing. Or the 09 AT yaris' really do suck at MPG.
Old 07-22-2013, 08:11 PM   #8
Overkill Fab
Drives: 13' Yaris HB
My brand spanking new '13 HB, AT with roll up windows gets 37-39mpg. On its third tank. I drive 100 miles round trip up hills and down. I try to keep it 60-65mph.
Plan to lower it, add front under tray, rear defuser, and side skirts. Then I'm gutting it down to the drivers seat. Aluminum exhaust post CAT, cold air intake. Replacing oil and tranny fluid with synthetic Royal Purple.
www.overkillfabrication.com
Overkill Fab is offline   Reply With Quote
Old 12-12-2013, 01:20 PM   #9
Brett!
Drives: 2010 3D base
I deliver pizzas with my yaris (still on my first tank of gas since I bought it..) and the first weekend I drove (about 200 miles over 2 days) I got between 38-44mpg the entire duration of delivery. I gotta say I am pretty happy with this car so far!
Brett! is offline   Reply With Quote
Old 12-12-2013, 04:49 PM   #10
JustPassinThru
Drives: No more Yaris
I don't know what you're doing to get this gas mileage.
With my 2009, with a manual, I got 38 mpg.
With my 2012, with an automatic, I'm getting 35 mpg. That's on pure gas, no ethanol.
Now I'm no lead-footed kid - I'm in my fifties and I drive...like an old fart in his fifties. I'm okay with the mileage but I'm not ecstatic.
Long time ago I had a Geo Metro 3-cylinder with a manual. I got 52 mpg with that. But that was about 800 pounds lighter - the added weight due to the newer safety standards.
JustPassinThru is offline   Reply With Quote
Old 12-13-2013, 12:46 PM   #11
Brett!
I am on my first gas tank at this time and am using a figure from my Automatic Link system - they may be giving me inaccurate figures. I currently have about ~335 miles with 2 bars left on the tank. If I do my math that is likely an average of 36mpg - still not bad, but my link had most of my trips at ~38-42 on most trips.
Old 12-13-2013, 07:19 PM   #12
nookandcrannycar
Part of it might be how flat this Houston metro is. Much of it is pancake flat. My Yaris has been in 46 states, and when I first bought my Yaris, I lived in the San Francisco Bay Area...and still visit. Houston metro = better MPG than S.F. Bay Area and many other areas.
Another factor might be the tire PSI level a particular owner is 'running'.
Old 12-13-2013, 12:08 AM   #13
mirapatec
mirapatec's Avatar
Drives: 2012 Yaris L, 2020 Yaris LE HB
Yeah, I wonder why some people get such poor fuel mileage figures. Even with numerous trips at Interstate speeds, I still obtain around 40 MPG per tank. I am extremely happy with this little car.
2012 Toyota Yaris L and 2020 Toyota Yaris LE HB
mirapatec is offline   Reply With Quote
Old 12-16-2013, 12:35 PM   #14
Brett!
after filling up it turns out I am getting exactly 36mpg. My link is either broken or not calculating correctly with the standard transmission
Old 12-16-2013, 12:44 PM   #15
Idahotom
Drives: 2008 5 sp. LB
I am anal about parking in the shade during the summer, and often the tiny Yaris makes that easier. I'll back into a space rather then forward if it keeps the windshield out of the sun, and I use a sunblocker. Heavy tint, and a white Yaris. If I am going to be parked for several hours, I'll compensate for the changing sun angles so that when I leave the preheating is minimal. For instance: leaving in the late afternoon, I'll choose a spot that aims east, even though that is right into the sun at the time. My tank averages are always in the 40's, low to mid.
Idahotom is offline   Reply With Quote
Old 12-16-2013, 07:31 PM   #16
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
The absolute worst MPG I've ever gotten was 27.x That was the first tank after I got my supercharger and quite a bit of time was spent at full throttle. I usually drive like I'm in Fast & Furious 9000 and still get 32mpg in town with a supercharged automatic sedan.
Old 02-13-2014, 03:14 PM   #17
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
My daughter gets 28MPG in Yaris in city driving this winter. Now, she is also known to get under 40MPG in my prius while I get 50-60MPG, so I should say the yaris almost meets expectations.
jack black is offline   Reply With Quote
Old 02-13-2014, 07:24 PM   #18
roxy1
Drives: 2014 yaris 5 speed
41.9 lifetime mileage. was higher but this winter has been pulling it down to about 40. 2014 5 speed. mostly light suburban and rural. 10-15% true city.
roxy1 is offline   Reply With Quote
Is the yaris best car for gas mileage out there? (in it's price class, of course) BennyLava General Yaris / Vitz Discussion 17 02-10-2010 07:33 PM
TO ALL PEOPLE THINKING OF BUYING A YARIS markpeppie General Yaris / Vitz Discussion 43 08-20-2006 09:27 PM
