![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
I drive a manual 3-door, 2007 1.5ltr yaris HB.
![]() ![]() ![]() Drives: 2007 Yaris Hatchback Join Date: Jan 2010
I also have a station close to me with ethanol free gas. I dont think the extra few MPG will be enough to offset the higher price. I dont remember for sure but I believe ethanol free gas here runs 30-40 cents higher per gallon
#3 | |
![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
Sent from my SM-J710F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
#4 | |
![]() ![]() ![]() Drives: 2006 Yaris RS 3-Door Join Date: Feb 2016
Apart from that, I love what you've been doing with your Yaris. Sent from my LG G2 with CM13 using Tapatalk |
#5 | |
you should see what they do down here in asia...pretty crazy.. Sent from my SM-J710F using Tapatalk
No reprogrammed ECU? No funny gasoline? ;-)
#7 | |
all the ecu were sold out except the cheapest ecu which was early timing advance...im waiting for 60mm throttle body to arrive so i can add fuel injection ecu... the complete piggy back and standalone is way too expensive...😣😣😣 Sent from my SM-J710F using Tapatalk
![]() ![]() ![]() Drives: Big Yellow Join Date: May 2009
When it comes mileage you can't beat a manual gear box. You can throw it into neutral and glide, or keep it in your tallest gear for DFCO, or even just engine brake every chance you get with DFCO to save gas. Of course idle can typically run lower in neutral at a stop with a manual. All of these things mean you have to think preemptively. My wife learned to drive a stick on the Yaris a year ago, and one of the comments she made after getting used to it was that you really tend to think ahead a lot more. As an avid cyclist and motorcyclist I can say that thinking ahead and reacting preemptively is definitely the safer way to go anyway
Sent from my SAMSUNG-SM-J120AZ using Tapatalk |
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
That would be Trillian?
Unfortunately my wife refuses to learn to drive a manual, so I'm stuck with an automatic. I normally drive the Yaris, and she drives our other car, a Toyota Aurion (that's the V6 Camry here in Australia). It has a long term fuel average display (digital) and a string of LEDs as an instant fuel usage display. At least that has taught her to be a bit more gentle on the throttle....
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
I often coast in neutral on an auto gearbox. Legality be damned.
Ha ha, good one! Having two heads means he can avoid accidents by looking two different directions at the same time. Just as long as he doesn't switch on his Yaris' Infinite Improbability Drive Sent from my LG G2 with CM13 using Tapatalk |
Have towel. Will travel.
![]() Drives: 2013 SE Join Date: Dec 2016
I'm a little shocked by the claims in this thread about 30 MPG+ in city, and even 40/70. What?? Either I'm reading this wrong, or I've got quite a different setup.
Here is my situation:
dunno about hwy yet, nor have I calculated my own fill ups to compare with what Yaris thinks - haven't owned it long enough. But assuming the computer is even in the ball park, this is a far cry from what folks are claiming here, no? |
#13 | |
now about avg 10km with E85...sometimes more than 12km on the highway... Sent from my SM-J710F using Tapatalk
#14 | |
![]() ![]() ![]() Drives: Yaris T-Sport Join Date: Nov 2016
Ethanols consumption is said to be 30% more than normal additional gasolines ! If so then your readings are not bad at all ! |
EDIT:
No, it's not E85 bio. It's just petrol (which apparently is mixed with maybe 10% ethanol around here). I run 85 octane because that is normal at this altitude. When I lived at sea level the lowest you could buy was 87. (Utah vs Seattle, WA) |
I know that back in the day when this forum was loaded with hyper-milers, many reported upwards of 46-48 mpg. Fifty was the holy grail. Again, that was by applying aggressive hyper-miler techniques.
I have always clocked between 30-33 mpg with my car. That's with over-sized wheels/tires and driving everywhere with a healthy pace. I'm sure I could get closer to 40 mpg with OEM wheels and by taking off my lead shoes. |
I "hypermiled" a couple years ago when my engine was stock. Only went 100km/h on the highway and drafted trucks some times. I averaged 5.3L/100km
Now I actually have fun when I drive and enjoy it and on summer gas I average 5.8-6.0L/100km That's aftermarket flow bolt ons
The stuff I remember in addition to drafting are things like never driving over 55 mph, coasting in gear down any hill/grade to take advantage of DFCO, driving as if your car doesn't have brakes, never driving with the AC on, etc.
They lost me at never driving over 55. |
| Tags |
| automatic, manual, mpg |
| Is LSD Automatic & Manual Same? | maxgil05 | Performance Modifications | 4 | 04-24-2009 10:57 AM |
| Want opinions automatic vs. manual transmission | anik | New YARIS Purchase Forum | 84 | 07-10-2007 04:25 PM |
| Change automatic to Manual | Blenjar | General Yaris / Vitz Discussion | 11 | 06-14-2007 06:02 AM |
| Manual vs. Automatic ?? | YarisBlazer | General Yaris / Vitz Discussion | 12 | 08-13-2006 07:14 PM |
