#1 | |
LOL
![]() Btw guys, I looked up the code I had and it was P2238, "O2 Sensor Positive Current Control Circuit Low." Anyone have any ideas? As expected, it seems to be related to the A/F sensor. Like I said, the fact that I still get readings on the narrowgauge means it can't be ruined. I still had the CEL when I turned the car on an hour ago too... Does the code just have to be cleared? And videos.. Soon... Need to find our camera... EDIT: I'm pretty sure there's a short circuit in the +B wire. Will do a continuity test tomorrow. Last edited by Focus_Sh1ft; 09-02-2010 at 09:24 PM. |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
Sounds like you got a bad O2 sensor. This is the top sensor before cat. converter. Or possibly your car is runing very rich with the 1zz injectors and may need tuning with the AEM FIC. What does your wideband sensor read?
Bathroom + Laptop = <3
Only Happy When it Rains
you should have videoed that, I am sure it was great entertainment.
Colin Chapman disciple |
CEL solved. Surprisingly, it was the wire I run off the narrowband gauge, It was either short circuiting / open circuit, but once I cut it the CEL disappeared. All other wires were showing continuity and the correct voltage, so I was getting a little worried.
I also extended the A/F sensor wires and ran it through some heat retardant plastic conduit. I have it running away from the downpipe to the ECM, then across the top. If there was any wire burning issues, this should hopefully be resolved now. Also had a small coolant leak STILL. I finally just replaced the brass fitting I was using and it seems to be ok now. As soon as all these damn problems stop coming up I'll get more pictures and video up lol. It's been over a week of battling problems and I'd like to just drive the car care-free.
God I need a code reader...
Got another CEL tonight. No idea what it is, but I'm assuming it's O2 related again. I wouldn't be surprised considering I put electric tape too close to the sensor and its become molted and is boiling on the O2 sensor lmao. Gonna uh... Clean that off before drawing any other conclusions. |
Pulling in more air and running a different AFR than expected more than a certain # of seconds will throw codes im thinking. ECU is constantly adjusting for the airflow and fuel. This only happens when you enter boost? You install your management system with a MAF clamp and a narrowband adjuster to make it seem like the ECU only sees 14.7 all the time?
P0101 is new as of yesterday. I've done a decent amount of driving without getting this code so it's weird it would suddenly pop up. I'm still pretty sure P2238 has something to do with wire damage from the heat off the turbo. And management is not yet in use, so until now the ECU has been doing just fine.
Eh, I'm beginning to think you're right about P0101. It makes sense that while boosting it's easily possibly to return a voltage signal that exceeds what the ECU is expecting. Why it's suddenly decided to start happening... Who knows? Edit: I just found that P2238 could also mean "Barometric Pressure Circuit Intermittent," when in relation to Toyotas. If this was the case, wouldn't it make more sense to get these two codes together? Last edited by Focus_Sh1ft; 09-05-2010 at 11:55 AM. |
C'est la vie
I extended my O2 sensor wires so it would reach my downpipe and I could route them away from exhaust. My downstream O2 sensor [after coverter] I just left connected and pulled through grommet hole inside on car. It is now under my carpet on the driver side. It took a long ride but my engine light came back on as well. Most likely for the downstream O2 sensor. I am hoping it is a converter efficiency code or evap. code due to boost pressure in the system.
I will go to autozone tomarrow and have them scan it. My scanner is not working on the newer cars.
#11 | |
#12 | |
pimp my yaris, lemme know what code(s) you have asap. Best case is we have similar codes... It's interesting that it took a good deal of driving for your code to come on, because it was the same with me. You'd think that if this theory is correct that the light would come on almost immediately. I need to check how the ECU tests for this and determines there's a problem... |
Ok, I looked into all this further and realized two things. Firstly, the codes wouldn't come on immediately because it takes two drive cycles for the ECU to determine there is actually a recurring issue. Secondly, I was reading these codes as per the Yaris manual hosted online. P0101 definitely seems to be the maf signal voltage out of range (too high), as a result of boost conditions. As for P2238, the manual lists it as the O2 sensor acting up, not the barometric pressure circuit intermittent. I THINK this is a result of the car running excessively lean. Low positive current on the AF+ wire directly equates to lean conditions. I have a scangauge on the way so I'll run some diagnostics before getting tuned.
Definitely would rather see CELs after boosting than not seeing them. Otherwise the car would clearly just be baffled as to what's happening to it lol. The cool thing is that if I'm right, a tune will sort out those two CELs. MAF clamping to represent boost conditions, and the proper air/fuel ratio done by fuels map would eliminate P2238. |
C'est la vie
P0101 is cyl. #1 missfire detected
C'est la vie
Mr. 155 and climbing
how do you have your gauges set up? Can you take a picture?
![]() Top -> Bottom = Boost -> Narrowband -> Trans Temp Transmission temperature is currently not installed. The gauge pod is a generic one from Summit Racing, and it fits pretty eh, but it works nicely. It comes with foam to fill gaps, but I don't care enough. ![]() Here's the turbo timer I'm not using. The gauge next to it is oil pressure. To the right of it is a voltmeter. I just wanna point out that they're not really 100% setup because I'm waiting on blue LED bulbs for the backlights before I seal the gauges in place and hold the pods with screws in the dash. I have a scangauge on the way that will sit on the steering column. |
I'm curious why you are using a narrowband?
| FS: Autometer Cobalt 6170 Boost Gauge | Nexus1155 | Items for Sale by private party | 2 | 02-02-2011 04:08 PM |
| Multiple cylinder misfire under boost | LtNoogie | Forced Induction Forum | 13 | 11-02-2009 04:44 AM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
