but, where's the fun in driving a turbo'ed car sensibly all the time?
![]() You *could* use a variable potentiometer, or switches, to change the water temp tweaking on the fly, when needed. As for what you need to tune in open loop, there are loads of options out there, personally I would want to get my hands on an inexpensive apexi S-AFC and a wideband O2 gauge to see just how effective this kind of tweaking can be, even without boost (the Yaris does seem to generally run quite rich in open loop mode, might be just mine, but there's certainly some power to be gained by leaning things out at high RPMs)
You can pull the second O2 sensor, forcing a constant CEL, then tune the car. That is what ZPI did.
It's a really lame approach, though.
#3 | |
But back to my original question, is tuning closed loop even necessary? Because it's going to be a PITA... Also - I hardly drive "sensibly" lol. But I just don't get it... If I'm not driving hard enough to enter open loop, then wouldn't I be best off just continuing to run stoich? Or is the hotter intake air too dangerous to run at 14.7 at all times? I DONT UNDERSTAND LOL. Last edited by Focus_Sh1ft; 10-04-2010 at 05:45 PM. |
The water temp trick will set a code eventually anyways. My parents Matrix set this code on it's own because the thermostat went bad and the car wasn't warming up fast enough. It took a long time to through the code though, as we found it wasn't heating up very quickly for a long time. PS it's only a '03 so I'm sure the Yaris has an even smarter ECU.
if you are in boost AT ALL, you don't want to be at 14.7. You should be able to make boost without going WOT.
Clear?
#6 | |
So this means I do need to tune closed loop... So my options are what I originally stated - force the car into open loop or manipulate the O2 sensors. I guess I don't have much of a choice but to start fooling around with the O2 sensors.
Rollerskate
Hey focus this is what you need to do not trying to be an ass here but you should take the car to a pro but if you don't want to here are a few thing to remember about tuning 1st it's always easier with two people but not needed ok when you start tuning you want to tune a no load meaning idle like I said before your looking for a a/f of 11:2 to 11:5 I'm not trying to tell you anything wrong if you take Otto a tuner that's what there going to look for so at idle set it around 11:5 after you get that then start with a light load don't get in to boost this is where two people come in hand as your driving cool at your gauges and the pc when you see your starting to leave the sweet zone of 11:2/11:5 then stop make a few changes and start again after you get that set the keep giving it more of a load and more till you have ran put on rpms to play with but always stay in that sweet zone of 11:2/11:5 there is no need to play with the 02 other then with the fic everything can be done with the pc as soon I get my oil leak under controll I well start tuning with my fic and when I'm done I'll give you a full tune of 8psi or what ever psi your running but like I said there is no need to play with the 02 other then using the pc
And for those that think I wrong go ask any pro tuner and the will tell you everything I just said I have tuned using aem before so I know what I'm talking about
Its a roller-skate get it right add me on facebook if your from nc my email for facebook is drifter704@yahoo.com |
Rollerskate
Sorry about my spelling I'm using my iPad and it mess-up some of the words
Rollerskate
Yep I haven't done this for the last 3yr I haven't tuned anything with more power than a yairs so thing what ya want and ill do as I've done ill quit tryin to help more power to ya camelll
^ Sorry but you WERE incorrect on several of your points. Go ahead and "do as you've done", or stick around and learn something.
We each make our own choices, and you can make yours for you car, but posting totally incorrect information will rightfully get challenged.
Guys, thanks so much for the input.
1.5ty, I appreciate your help but I know for a fact that technique is not going to fly with this car. I've added fuel with the FIC while idling and watched the AFR drop to 14- on my wideband then get immediately corrected. Open loop and closed loop are a big deal here. Camelll, thanks so much bro. I've been wondering how Blitz handled this. Unfortunately, it gives me no more information than I already have. ![]() What I find interesting is that you're boosting for awhile while in closed loop, correct? About what PSI do you reach before open loop kicks in in your case? The fact that you've been running two years successfully while boosting in closed loop really leads me to question how unsafe 14.7 is under light boost... Yes, I know I'm comparing two completely different things, but boost is boost - hot compressed air being forced into the manifold. Feel free to correct me if I'm wrong. |
^ open loop doesn't kick in at a psi. It kicks in when the ECU senses a certain load, 75% throttle in our case, and maybe under some other conditions, I don't know.
#13 | |
...Am I just not driving my car hard enough? lol
we actually brainstormed and did some research about this a few years back, if you wanna take the time to sift through it:
http://www.yarisworld.com/forums/showthread.php?t=15350 http://www.yarisworld.com/forums/showthread.php?t=21431 Pay close attention to the excel files linked, PK did some good data logging, and yes, no matter what your car is doing, what gear you're in, mash the throttle past the 75% signal and it'll go open loop. In my mind, the ideal "simple" setup around open and closed loop would be what I call the Jekyll and Hyde approach. A boost controller set up for very gentle boost (maybe 5psi) for use during closed loop operation, and higher boost for open loop, and this would be triggered by the throttle position sensor. Add to that a piggyback that can also have different profiles based on throttle input (such as the apexi SAFC mentioned in the second link above), so that it'll let the ECU do its thing in closed loop, but then mess with things once the throttle goes past 75%. So, driving "normally", you get the benefit of added power without reaching the limits of the engine/ECU, but when you put your foot down, then you get extra boost, and the piggyback to provide more appropriate fuelling, to unleash the beast within
#15 | |
I don't think you can do that with TBW. If the ECU sees more than what's input and the output of the throttle plate doesn't match, it'll go into failsafe.
another (cheaper) piece of electronics to fiddle around with the MAF signal in open loop, the HKS AFR (Air Fuel Regulator). Very simple little box with a dial for the degree of adjustment of the MAF signal (leaner or richer). Nowhere as precise as a proper piggyback, as there is no RPM-specific or throttle-specific arrangement, but it could work well to get an *overall* richer or leaner fuel mix while in open loop, similar effect to getting bigger injectors, I suppose!
No updates on tuning unfortunately, haven't had time to deal with it yet. However, I did redo my oil pan as per Garm's observation about the removable stems. No leaks from it now
Unbelievably though, I'm now back to dealing with coolant leaks. I don't know what the hell I'm doing wrong. I switched to M12 adapters that fit on the turbo VERY snug, but yet they still leak! I was so pissed when I noticed this yesterday, because I really don't know where to go from here. I'm thinking about just yanking water cooling ![]() The only thought I had was that the hole on the adapters is too small and is creating a huge pressure buildup, which causes the coolant to back out through the threads. I have some pictures, but they suck. Basically, the diameter of the holes is about half of the lines I'm using. The adapters were really meant to be used for getting a pressure reading for a gauge. What do you guys think? This is all getting incredibly frustrating... I just don't have time to deal with this BS over and over again with my classes. Oh, and I'm not even going to begin on how impossible it was to get those stems off. Unless you have an M4 female torx socket, you're practically SOL. Last edited by Focus_Sh1ft; 10-11-2010 at 11:28 AM. |
| FS: Autometer Cobalt 6170 Boost Gauge | Nexus1155 | Items for Sale by private party | 2 | 02-02-2011 04:08 PM |
| Multiple cylinder misfire under boost | LtNoogie | Forced Induction Forum | 13 | 11-02-2009 04:44 AM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
