keep on keeping on... you almost there
#2 | |
Bathroom + Laptop = <3
Another way to do it is to remove the connectors to the ECU and it won't start just crank. Usually smoke burning off is also from working on the hot area with oil or another substance on your hand needs to burn off, but like someone said it could be header wrap or paint too. ( Well I wrote that for nothing since I just read the last part of your post lol) Glad to see its working well for you :D |
yay "almost" welcome to the Club
I definitely agree with priming ANY turbo. It's easy to do and there's a million ways to do it, so why not?
Nexus, reading your post reminded me of something interesting I noticed when I first inspected the turbo. I think Zage sent me a "pre-primed" turbocharger. There was oil on it, and at the time I immediately dismissed it because I thought it had simply come off my hands. Eh, doesn't matter now. ![]() Current progress: all coolant leaks are sealed. Have a very slight leak coming from the banjo bolt that I resealed again, so that should be covered. The return flange on the turbo is leaking quite a bit of oil though... Will address that tomorrow... er, later. Oh and also... My CEL disappeared, once again. So it was probably that supposed TB code I seem to get every time the ECU is reset. Should be interesting to see if I get another one when I start driving around. ![]() Man did I earn it.
Yeah man, why not take precautions? Honestly. It's a car, what can go wrong will go wrong. In the S4 I need to take the engine out to swap turbos, and the lines need to be in specific places or they will melt from excessive heat. It's little things like priming the turbos gives peace of mind not having to go through BS removing and installing them again. I just ran without a cluster to see if it will work and run, apparently my oil pressure was low, no cluster, no lights. KNOCK KNOCK KABOOM goes one of my rods.
Yeah, the turbos usually have little caps on them, one time one was full of oil and just spilled all over my lap. -_- the coolant line you JB Welded? Is the oil return gasketed? |
Still (patiently) battling an oil leak from the turbo. I'm not entirely sure where it's coming from... There's definitely a small leak at the least from the banjo bolt, but I still don't know about the return flange. I've used like half a tube of JB Weld at this point lol... I think the problem is the leak is in a spot that I can't reach.
And yes, the oil return has some sort of gasket. |
#7 | |
![]() ![]() ![]() ![]() Drives: Yaris LB Turbo Join Date: Aug 2006
#8 | |
What I'm currently thinking is the way the return line is setup is causing a huge oil buildup, thus causing a large enough rise in pressure to finally leak out of the return gasket. It's the only thing that makes sense at the moment... I made sure all my seals were VERY tight. |
#9 | |
![]() ![]() ![]() ![]() Drives: Vitz RS Turbo Join Date: Nov 2008
Just a hint! |
#10 | |
Based on what you guys have said and what I've read, I'm pretty convinced I over tightened the flange and thus damaged the gasket. I was watching the oil while my car was idling and that's exactly where it was coming from.
well atleast its an easy fix, alot of places have Mr. Gasket material. I'd even ship you some if I didn't give the rest to my DSM buddy, but im sure you want it fixed ASAP too lol. The stuff I had for gaskets might have been a little too intense for just a drain though.
Hurry up and fix it so we can see some vids!!!! :) |
C'est la vie
Drives: 2009 2 door hatchback Join Date: Aug 2009
I would buy some paper gasket material from local auto parts store and cut it to the shape you need. Then coat it with a light layer of rtv silicone sealent. Then reatach and dont overtighten the bolts. If its to tight the gasket will just squeeze out the sides. Good luck Jerzy
#14 | |
If you guys haven't figured it out, I'm desperate to NOT have to pull the turbo back out. The thought of doing that... ![]() Yeah and Nexus, I'm as eager as you are dude. I have a boosted Yaris sitting in my driveway, and the only thing stopping me from driving it is a tiny oil leak. ![]() EDIT: Forgot to mention I'm already almost done putting together my install guide, if anyone is interested. I tried to make it as comprehensive as possible. |
I skimmed it over, is this guide going to ZAGE? Looks pretty in depth though which is good. LOL I like the use of gaybolt.jpg.. I don't know if you were trying to, but you might want to try to embed the pics? I don't know if you did because Word did something funny with converting the file, but yeah I'll read it when i get back from the garage.
#16 | |
![]() Really though, how many turbocharged Yaris' are there in the states currently with me included, five? Also, thanks a lot for the cheers of joys guys, but apparently I'm not quite there yet... Was driving to work today, oil idiot light started flashing and then stayed on, accompanied by a CEL. I'm still leaking oil BAD. Had to stop and buy 4 quarts of oil. Immediately threw 2 in. Had to throw the third in on the way home. Hopefully I was prompt enough in dealing with it. I was watching my oil pressure closely and was getting worried... sure enough. So, it's time to stop beating around the bush and deal with this the right way. I have all day available to me tomorrow, so the turbo + downpipe will be coming out. ![]() This time around, I'll seal the banjo bolt + washers, return flange, return gasket, return bolts, etc. with silicone sealant. I really should have done this the first time around, but I had no idea this was going to happen. Will also inject the turbo with the crappy oil I had to buy and look for leaks. If anyone else has any other ideas or thinks silicone is going to suck for this use, let me know immediately. On the positive side, I was able to (hopefully) drive this thing without doing any damage, so it'll be a lot easier to be patient now. I still can't even begin to describe how much fun it is to drive this car. I swear, everytime I see the needle on my boost gauge pass the 0, I get such a huge smile lol. Between my exhaust and turbo, the noise and feeling when you hit the throttle.. is intoxicating ![]() On a side note, I felt it was time to change my ride details. |
Congrats! You did what most people wouldn't and couldn't do (including me)! Dyno that puppy and upload some videos.:)
woot happy for you man GOOD JOB!!!!
| FS: Autometer Cobalt 6170 Boost Gauge | Nexus1155 | Items for Sale by private party | 2 | 02-02-2011 04:08 PM |
| Multiple cylinder misfire under boost | LtNoogie | Forced Induction Forum | 13 | 11-02-2009 04:44 AM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
