Old 01-16-2007, 09:10 PM   #1
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
got the trd suspension installed...
but now the tops under the hood are sticking up about 1/2". it didn't do this on the stock suspension. i took my car to a performance shop here in dallas and the mechanic took the left side apart and examined it. he said there is nothing wrong with the way it is currently setup. i asked him if this was dangerous to leave it the way it is and he said most likely not. he said the new volkswagens also have the same setup where the tops stick up about 1/2" when the car is on the ground. he also mentioned working on a new 06 mercedes a couple of weeks with the same type of suspension design and it was also like this.
anyone else notice this? i have talked to another member on this forum and he said his is exactly the same way. i'm thinking maybe this is how the car was designed...?
tekmoe is offline   Reply With Quote
Old 01-16-2007, 09:12 PM   #2
ChinoCharles
Drives: LB
The tops of what?
How do they feel?
Old 01-16-2007, 10:38 PM   #3
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
The tops of what?
How do they feel?
x2
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 01-17-2007, 12:00 AM   #4
tekmoe
ex-yaris owner
sorry guys. i mean the tops of the struts that stick up into the engine compartment under the hood that are held by the single nut on each side. with the stock struts, the tops were flush with the chasis. with the trd struts, the tops sit up about 1/2" from the chassis. the car feels fine and i don't hear any weird noises coming from the engine compartment.
ken at sparkstrd says i should not be driving the car. after talking to the mechanic at the performance shop it sounds like the car is perfectly fine to drive.
just wondering if anyone else is in the same scenario...
Old 01-17-2007, 12:16 AM   #5
Black Yaris
der Zeck
Black Yaris's Avatar
by the "tops" are you refering to the strut mount, also know as a bearing plate? As far as I knew the upper strut mount is not changed when installing a lowered suspension, not even a TRD one.
Old 01-17-2007, 12:54 AM   #6
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Do you have the struts and springs, or just the springs? Springs alone should not change the top of the strut. TRD struts on the other hand, I don't know. You need to find someone on here with the TRD struts to compare.
PetersRedYaris is offline   Reply With Quote
Old 01-17-2007, 08:37 AM   #7
tekmoe
ex-yaris owner
yeah i changed both the struts and the springs to trd.
black yaris, i'm talking about the very top of the struts where the dust cover fits onto.
Old 01-17-2007, 10:48 AM   #8
03Z33
03Z33's Avatar
Drives: TCR10
That's normal. Nothing to worry about, I can try to snap a picture of my setup later to show you it looks the same. Did you use an air gun to tighten both nuts (below and above the strut bearing)? If so, you should be good to go.
03Z33 is offline   Reply With Quote
Old 01-17-2007, 12:27 PM   #9
tekmoe
ex-yaris owner
ken at sparkstrd insists something is wrong and that by driving the car like this it will create problems. he keeps telling me the trd engineers say it should not be like this. when i took the car to the mechanic yesterday, he took it apart and said there isn't anything that can be done to stop the top from sticking up. i'm so confused right now.
at this point i am leaning towards what the mechanic said. basically the rubber bushing between the chassis and the top cap has all the weight on it. he even said the new volkswagens have the same exact design where the tops stick up about 1/2".
this is so irritating.
Old 01-17-2007, 12:38 PM   #10
Can you take a picture of what you mean? it's really woth 1000 words
Old 01-17-2007, 12:45 PM   #11
tekmoe
ex-yaris owner
yes, sorry. pictures really do tell most of the story.
Old 01-17-2007, 12:48 PM   #12
Doc Zaius
Lurker supreme!
Doc Zaius's Avatar
Drives: old and boosted!
I'm pretty sure mine stick up a bit too... I'll look when I'm home.
2006 Red Blitzed RS 5-door
Old 01-17-2007, 12:49 PM   #13
tekmoe
ex-yaris owner
that's the general consensus i am gathering. i'm glad i'm not the only one. i just don't feel good when a TRD engineer says it should not be doing that. thanks for your input.
Old 01-18-2007, 01:19 AM   #14
johnnyfive
johnnyfive's Avatar
stole this pic from chris's diy spring change thread, but definetly stock cap does not sit like that....and with just lowering springs installed mine definetly dont look like that...might be a function of the new struts, but i definetly dont like how it looks....
johnnyfive is offline   Reply With Quote
Old 01-18-2007, 08:26 AM   #15
tekmoe
ex-yaris owner
i got an email back from ken at sparkstrd and he says hes has confirmed my car is perfectly normal.
i'm gonna stop worrying about it. it's not healthy!
Old 01-24-2007, 04:58 PM   #16
Go4th
Go4th's Avatar
Drives: Yaris S Sedan color Flint Mica
Question Alignment after just TRD spring install.
any one need to have an alignment after just the trd springs install?
web site (trdsparks thats selling them) says "The TRD Red Lowering Spring Set lowers the car 1.2” in both front and rear without changing the vehicle’s suspension geometry."
Dose this mean you dont have to get an alignment?
Go4th is offline   Reply With Quote
Old 01-24-2007, 05:25 PM   #17
tekmoe
ex-yaris owner
my car drives the same as it did before i installed the springs and struts. i don't think an alignment is needed.
Old 01-24-2007, 07:20 PM   #18
largeorangefont
Break'em off some.
largeorangefont's Avatar
Drives: 07 Yaris LB, 04 Cobra
I would get one after a couple weeks when the springs settle in
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 10:26 PM
Fs: New Trd Stickers & Emblems !!!!! located in So cal Trd86 Items for Sale by private party 13 06-25-2007 05:49 PM
TRD Parts MC-BPT Sponsors Classifieds Area 9 06-23-2007 11:51 AM
PICS OF TRD INTAKE INSTALLED! elsteverino889 Performance Modifications 9 03-03-2007 05:12 PM
What's the typical price, dealer installed, for the TRD lowering kit? St_G Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 01-17-2007 11:57 PM
