Old 07-19-2010, 10:28 AM   #1
Yarus Maximus
Drives: 2010 Yaris 5-dr auto
What is your stock tire pressure?
My stock Toyota tires are set to the recommended 32 psi. Is yours at a different pressure? How much and why?
Yarus Maximus is offline   Reply With Quote
Old 07-19-2010, 11:21 AM   #2
djct_watt
Drives: 2010 NCP91 5spd
41psi. . .
. . . because of prolonged speeds over 130kph, mileage, and tire longevity (I always wear out the outsides of the tire first and over-inflation gives we even wear).
Old 07-19-2010, 11:24 AM   #3
127.0.0.1
40
little more mpg
little less wallow
I have used 40 psi x 4 on all my vehicles since 1982. it is just what I do has nothing
to do with vehicle type or use.
I will deflate for sand and special circumstances
Old 07-19-2010, 11:39 AM   #4
Yarus Maximus
At 40 psi my dashboard rattled when driving over bumps. Have you experienced more noise at that pressure?
Old 07-19-2010, 11:46 AM   #5
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
42psi on stock tires.
Old 07-19-2010, 11:51 AM   #6
djct_watt
No rattles, except some from the hatch that have always been there.
Old 07-19-2010, 11:58 AM   #7
2007yariz
Drives: Yaris sedan
Yaris sedan here, i try to keep it at 35psi.
But my door jam says 32 psi on all four tires...
2007yariz is offline   Reply With Quote
Old 07-19-2010, 01:48 PM   #8
TwoBearWisconsin
TwoBearWisconsin's Avatar
Drives: 2010 Yaris LB/5, 1996 Miata
40 psi on all four for me.
TwoBearWisconsin is offline   Reply With Quote
Old 07-19-2010, 02:28 PM   #9
fearturtle44
Drives: S Flint Mica
I keep mine at 32-33. Stock tires lasted 40,000 and now have a 60,000 tire which I am also keeping at 32-33. Got nitrogen this time. Might be a waste but wanted to try.
fearturtle44 is offline   Reply With Quote
Old 07-19-2010, 05:23 PM   #10
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
44 PSI. I've run all my tires at max sidewall pressure as long as I've driven.
Old 07-19-2010, 05:31 PM   #11
kimona
kimona's Avatar
Drives: 2014 White VITZ
At 40+ PSI, my car bouces all over the road like a basketball!
Old 07-19-2010, 06:07 PM   #12
yarrr
Drives: 07 sedan
That's the secret to uber gas mileage. Get the car bouncing, shut off the engine, and watch her bounce down the road, gas free.
yarrr is offline   Reply With Quote
Old 07-20-2010, 03:07 PM   #13
Vang
Drives: 2008 Yaris Sedan
35psi
Vang is offline   Reply With Quote
Old 07-20-2010, 03:27 PM   #14
35psi... I tried 40+ on my old 18" wheels, it really made it a lot more harsh and not a noticeable mileage improvement. Might try it again on these 15" wheels after a couple more tanks...
Old 07-20-2010, 06:39 PM   #15
BailOut
Steals terrorist's lunch
BailOut's Avatar
I run 60 PSI year round for both lower rolling resistance and much stiffer performance in the switchbacks in the mountains here.
Folks on this forum go ape shit every time I bring this up so be prepared for a thread derailment, but the only things I'll say are that I've never had a problem with this, it brought greater longevity to my tires, and I've even avoided becoming the 4th car in a 3 car accident thanks to my preparedness and alertness as well as the car's agile handling, even at 60 PSI. I even had a big puncture from a gnarly piece of metal I picked up and it didn't act any differently than blowing a tire at 35 PSI.
It just works, so get over it.
- Brian
Share the Road
Old 07-20-2010, 07:02 PM   #16
KrazyDawg
KrazyDawg's Avatar
Drives: 08 3dr LB AT
Max side well of 44 PSI. Higher tire pressure is safer than lower tire pressure. You have an increased chance of having a blow out with a lower tire pressure. Lower rolling resistance and increased longevity are the result of a higher tire pressure. When you adapt your driving for DFCO, it makes you more aware of the road ahead.
Note: For every 10 degree change in temperature in Farenheit, it's 2 PSI.
KrazyDawg is offline   Reply With Quote
Old 07-20-2010, 08:18 PM   #17
centrysis
centrysis's Avatar
Drives: '08 Yaris LB
my tires arent stock but I keep mine at the max pressure of 44 psi.i'm running 215/35/18's though
centrysis is offline   Reply With Quote
Old 07-20-2010, 08:25 PM   #18
R2D2
Crazy Oil Sniffer
R2D2's Avatar
I run mine at 60 psi as well. Might be a tad more road noise but the car rolls freely and handles great.
-The Fitful One
Tire Pressure Monitor Sensors....? 09TRD Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 12-19-2008 10:25 PM
Tire pressure sensors Tink1 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-21-2008 06:53 PM
2008 Yaris with Tire Pressure Sensors nsmitchell General Yaris / Vitz Discussion 2 08-23-2007 12:34 PM
FS: Stock 15" RE92 tire GabL Items for Sale by private party 9 07-02-2007 03:20 AM
The Tire inflation debate... Tankota General Yaris / Vitz Discussion 20 06-01-2006 08:09 PM
