Old 08-16-2010, 12:29 PM   #1
Y@R15
Dude wheres my car?
Drives: 98 honda VTi
this is also true the A/C is only effiecent in the 60+MPH range. in this speed having the windows down would kill your MPG as well. what your talking about it trying to gain by saving. you cant gain power and MPG when you have the A/C on. now a way to i think see a little less fuel consuption would be to use an aftermarket A/C pulley. like the crank and altinator pulleys. other then that. your not gonna see anything by useing the A/C air... i think i confused myself.
Y@R15 is offline   Reply With Quote
Old 08-16-2010, 09:16 PM   #2
cfeng
Drives: Yaris 2010 Liftback
if someone tells me the mass flow rate of the air, or mass flow rate of the fuel, that passes through the engine, i can tell you how much more air can be consumed by an air conditioner operating 1.5-2 kw, cooling about 4-5 kw. i can approximate what power gains may be achieved.
correction to previous post, this would not be considered a forced induction at all, since pressure does not change due to cooling.
cfeng is offline   Reply With Quote
Old 08-16-2010, 11:46 PM   #3
djct_watt
Drives: 2010 NCP91 5spd
Just do a MPG check, one with AC always on and one without. Last time I did it, I saw almost a 5% reduction in MPG, so it should be close to the same in power draw. Don't forget that small numbers are usually within margin of error for dyno pulls.
Here's a link to a discussion about HP draw of an AC unit.
http://www.bobistheoilguy.com/forums...Number=1944982
djct_watt is offline   Reply With Quote
Old 08-17-2010, 02:52 AM   #4
You're saying it's a 1:1 proportion of MPG to power? That doesn't sound right at all.
Old 08-17-2010, 03:00 AM   #5
djct_watt
I mis-phrased, lol. Definitely not 1:1.
Cold air intake vs air intake Liu997 Performance Modifications 15 11-05-2009 06:32 PM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 04:16 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
