#1 | |
![]() Drives: 07 Yaris Join Date: Jun 2010
Also, let's say there's a blue wire in pin 40...could it be removed and a new wire run directly to D3, bypassing AD4? Last edited by dbielawski; 08-16-2010 at 01:20 PM. |
#2 | |
#3 | |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
Scott..
Do we assume the conection between D3 and V1 are there?, have you ever checked your Yarris buggy/plow? I just reced the OEM CC stalk I ordered and pissed that Toyota went to all of the troubole to have the ECU with the CC software installed, and harness fabed with all the interwire connects except D3 to AD4! Man I hate those guys at Toyota!.. P.S...Do we know the terminal specs or the termial size part# if I wanted to add the two connects to D3.. The terminals are very small and I have never seen this type at any local electronic store.. P.P.S.. Scott, have you ever take apart your gauge cluster too see if the electrical traces are there for the CC light indicator in hoping that all is needed is possible a inline resistor and/or SM led |
#5 | |
D3 to V1 wires are definitely there, as there is only one clockspring used on USDM Yaris. My FAQ thread has the pin part numbers: http://www.yarisworld.com/forums/sho...ght=cruise+faq I have taken apart the non-cruise clusters and they lack anything related to cruise indication. |
Your sharing of information is much appreciated. Off I go to my mechanic with this information. I'll keep you posted. Thanks again!
OK..here is where I am at. On the clock spring at 3 wires/pins. 1 for horn, 1 red & 1 black. The cruise switch has a red & black. The black on the cruise is wired to pin 40 on ECM. The red on cruise is wired to red on clock spring. It still does not work. Where exactly do the 2 wires (red & black) of the cruise go? 1 goes to pin 40? One goes to ???? There are only 2 pins on connector D3, not 3???
#8 | |
I was about to say that you need to get your eyes examined in regards to the 2 vs 3 pins on D3, but then I took a look and noticed that on my 08 there are indeed only 2 pins on the clockspring side of that connector. The other pin for the cruise control is ground. You can simply tie the other wire to the frame of the steering wheel, since it is a chassis ground. |
#9 | |
![]() Drives: 09 Yaris 3 door M/T Join Date: Sep 2010
Aussie Yaris CC no-go?
Hi CTScott. I have a M/T 3 dr in Australia. Should I not even bother looking to see whether I can fit CC to my vehicle?
#11 | |
Any suggestions. Thanks! |
#12 | |
Based on the lights that came on, I would say at this point that your mechanic has the ECM pin in the wrong position. |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
| How difficult is it to install the aftermarket cruise control kit? | grampi | Performance Modifications | 3 | 07-19-2007 08:06 AM |
