Old 08-26-2010, 06:28 PM   #505
sqcomp
Roadrunner Jr.
sqcomp's Avatar
You want me to throw you some info on them? I can also see about B stock pricing as well...
― Thomas Paine
Old 08-26-2010, 06:30 PM   #506
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
info info info please!!!
THAT WOULD BE NICE!
Old 09-01-2010, 08:47 AM   #507
derickveliz2
The other day I was looking at a Mercedesbenz, inside the rear wheel wells they have some sort of turf material like an outside carpet, that's clever a good tip I bet it helps deadening the splash water hitting the fender on rainy days... how could we attach some of this carpet under there?
Another project on the "to do" list!
D.
Old 09-06-2010, 10:56 PM   #508
derickveliz2
Wink
Wow... been unemployed I though I was going to have a lot of free time, well... that's not the case, just looking for work turns into a full time job, besides trying to put all my ideas in order and try to work some thing out, it's been very hard.
On the other hand... my Yaris got a rear suspension make over! yeah I have a lot to post on the wheels and suspension thread, but my intention was to beef up the rear to support the big heavy subwoofer box. So far so good. Pictures soon...
PS... finally I got rid of the spacers and my rear tires don't rub any more. (o: [10mm spacers got stuck)
D.
CLA 250, 4MATIC
Old 09-08-2010, 08:24 AM   #509
derickveliz2
Ok, last night I put the heavy box with three 10 in Solo-Baric woofers, it's connected I didn't crank it up and feel the Bass, it was 2 a.m.
My big concern is the rear suspension and handling, I hope it's worth all the benefits towards SQ.
Old 09-08-2010, 12:06 PM   #510
derickveliz2
Thumbs up
OK, 3 better than 1.
The Solo-Barics handle bass much better than the Bazooka Tube, and Yes the box it's much heavier, I think I can live with it!
It's time to go after some little rattles in the trunk.
The Bass from the Solo-Barics was absorbing the Mid-Bass from the Lows in my doors (6.5" drive) This is where sqcomp has a tremendous advantage with his HAT's L8s low in the kick panels I had to bump up 2 dB (+2) and lower the Subs 2 dB (-2) for a perfect match.
The ability to "MUTE" each channel from the HU it's very helpful and teaches me about frequencies and how music comes out from the speakers.
D.
Old 09-08-2010, 02:41 PM   #511
derickveliz2
This is how it looks inside the cabin with mids on the dashboard... Note: tweeters not shown...
Old 09-09-2010, 01:09 PM   #512
derickveliz2
I got this article (Six Ways to Prevent or Eliminate Audio System Noise) from Car Audio and Electronics, it's a must read.
LINK TO ARTICLE
D.
Old 09-09-2010, 05:14 PM   #513
derickveliz2
Ok, after 160 miles testing the Solos, I switched back to the Bazooka this morning... my thoughs:
How heavy?
Solo-Barics --- 90 pounds
Bazooka --- 17 pounds
Car Handling?
Solo-Barics --- Feels very heavy, and not very responsive
Bazooka --- Very sportier stable and nimble, specially on the highway and at runs
How good they sound?
Solo-Barics --- Loud shakes all the car, better at high volume
Bazooka --- Not as loud %15 less than Solos, best for SQ at low-moderate volume
I'm confused / frustated
70 pounds doesn't sound much, but remember all the weight that comes from deadening, It feels like 5 adults + groceries
Old 09-09-2010, 05:33 PM   #514
FcukThis
Drives: yaris
whoa! three 10" Solo barics vs. a bazooka ?
Only 15% louder?!
Hm, to me-- that's a hands down bazooka win.
But some things to consider?
1.) What about kick/impact, Do you still get it with the bazooka?
2.) How about the rattles, do the solo barics produce any annoying jiggles in the trunk?--I had a pair of subs in my trunk several months back. I loved the way they sounded, but they rattled my car way too much.. Because of it, i hesitated to crank up the volume.
3.) Consider the low end capabilities, which hits lows better. And/or which will produce better sound for the type of music you listen to ?
4.) Power efficiency. Since we're only talking 15% loudness when comparing the two. The bazooka only takes 50watts compared to 200watts per say(I'm making up numbers) to power the solo barics. Less strain on your system.
5.) Weight, which you have pointed out. I used to drive to school everyday w/ a full load. (me + 4 friends). everytime i would get on the highway, it sounded like my car was going into overdrive.. Just horrible!! Handling...Oh boy, i dont even want to get started. It was hard to merge from lane to lane sometimes.
If the weight difference makes driving unenjoyable, clearly it's a no go!
Add the weight of your deadening, +70 pounds, +groceries, + your family/passengers. I can really see how things would add up.
FcukThis is offline   Reply With Quote
Old 09-09-2010, 05:33 PM   #515
47_MasoN_47
What I thought I'd do was
47_MasoN_47's Avatar
Drives: 09 Yaris Sedan
I believe you, I can tell a difference just in loading up a few computers in the trunk. So how much total weight did your deadening add?
Old 09-09-2010, 06:13 PM   #516
derickveliz2
BLUE TEXT IS "ME"
FcukThis;whoa! three 10" Solo barics vs. a bazooka ?
Only 15% louder?!
Either way... the Bazooka sounds too good or I'm disappointed with the Solo-Barics
At low to moderate volume Bazooka Tube does ass good as the Solos
Yes! Solo-Barics shake the car more than the Bazooka
Bazooka hits the lows better, Solo-Barics handle better the other end; at low-moderate volume the Bazooka satisfies me better, to SHOW-OFF I'll rather have the Solos, I don't know if you get my point?
My amp put out 300 watts:
Bazooka is rated at 300 watts
Solo-Barics are rated 350 watts each
The guru expert guys may explain this better.
Yes you got the point!
Me thinking...............
Old 09-09-2010, 06:15 PM   #517
derickveliz2
MLV= 1lb / sqfoot
MLV=90 pounds
MAT=70 pounds
so that's around 160 pounds, just estimating.
Old 09-09-2010, 06:17 PM   #518
47_MasoN_47
Holy crap, that's a good bit more than I'd expected.
Old 09-10-2010, 12:44 AM   #519
Alien Mantis
Secret Agent
Alien Mantis's Avatar
Drives: 2008 Yaris Hatch
[QUOTE=derickveliz2;509663]
SMACK!
This is your problem.
You don't have anywhere near enough AMP to push 3 Solobarics!
You need a 900 watt amp on those Solobarics.
You put a bigger amp on those things, and you will see a huge difference.
300watts is good for one Bachuka.
I am putting 400watts on one Alpine Type-R.
And it's just enough!
I would run a 900 watt amp on 2 Type-R's.
Underpowered subs suck, and you can actually hurt the subwoofer by not giving it enough power.
Lots of articles on the internet about this.
One other thing: did you ever tell us anything about the BOX those Solobarics are in? Sealed or ported? What Ft^3 ?
Also, what model Solobarics? L5 or L7 ?
( L7's are bigtime power hungry beasts )
How do you have them wired up? What is the total OHMS load? Are they single or dual voice coil? What ohm per coil?
What is the RMS power rating of your amp at WHAT OHM LOAD?
You gotta match up these numbers correctly, or you will cook your amp, or severely underpower your subs.
How about a photo of them!
Old 09-10-2010, 01:13 AM   #520
derickveliz2
Thumbs up
Originally Posted by Alien Mantis View Post
SMACK!
YEAH! I knew there was something going on beyond my knowledge...
Thanks AM I will be posting more info about them...
D.
Old 09-11-2010, 03:45 AM   #521
derickveliz2
Unhappy
Before I post the information of the woofers and amp, check this out!
The car is off and everything is quiet, I turn the HU on, music plays really nice (very low volume), then I pause the music... complete silence then I turn the parking lights on and I hear a small Bizzzzzzzzzzzzz on the right side Tweeter and Midrange...
I turn the lights off Bizzzzzzzz goes away.
any clues?
Thanks
D.
Old 09-12-2010, 12:20 AM   #522
DailyDriver
DailyDriver's Avatar
Drives: 3dr Lftback (meteorite) Manual
your speaker wires are running too close to your wires for the turn signal. u just need to separate them. if it isn't possible to separate them, insulate the crap out of them. if they actually have to cross, then cross them at 90 degrees or perpendicular to each other, and try to insulate them as best as you can. should be that easy. (fingers crossed)
DailyDriver is offline   Reply With Quote
