Old 01-11-2011, 09:48 PM   #1
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
hot rod
Old 01-12-2011, 09:19 PM   #2
xbgod
Drives: "Burning It Down GTX2860RS XB"
Well, it's over. Got this 20 min. ago...........final results gentalman. I'll get the video they shot over the weekend. Thanks for the support on this build.
XBG
xbgod is offline   Reply With Quote
Old 01-12-2011, 09:21 PM   #3
Tamago
Tamago's Avatar
Drives: UZJ100
conservative Hp numbers. you must be pulling lots of timing. . .
Old 01-12-2011, 09:31 PM   #4
xbgod
Thats what Rolo said.
VVTI is off and Microtech is still the main ECU right now. I have a Haltech unit coming in still but untill I get it I'll take the numbers I got.
XBG
Old 01-12-2011, 11:07 PM   #5
Congrats on some real nice numbers. Looks like it went very lean above 4k?
What was your boost on that pull?
How come it stops making power at 4200 rpm?
Old 01-12-2011, 11:16 PM   #6
xbgod
23 PSI on that run.
Using Torco 107 octane and VP M1 Meth.
Also still have not used nitrous yet. Just incase someone asks.
Going to go like this for 2,500 miles then try out the nitrous.
XBG
Old 01-13-2011, 07:10 PM   #7
Blown_xa
Blown_xa's Avatar
Drives: Scion xA
youre looking at the torque curve garm.
Ptuning.com
Blown_xa is offline   Reply With Quote
Old 01-13-2011, 12:10 AM   #8
PETERPOOP
PETERPOOP's Avatar
Very lean!
Nice numbers though. Couldn't imagine what 300+ whp feels like in a yaris.
Old 01-13-2011, 01:11 AM   #9
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Tuner needs to tune better.... you will have much greater numbers.
Old 01-13-2011, 10:00 AM   #10
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Sorry you are wrong here, richer mixture isn't equal to greater numbers infact it's the opposite way.
The best mixture is 14.7 stoich AFR and XBG map is going above it at lowest and highest rpm. So he is getting the maximum numbers he can achieve... richin the mixture makes the numbers lower but prevents damage to the engine
To Yoda... I think the conversion was made to account for the octane rating.... since at 3K rpm he's about maximum rich 10.
Old 01-13-2011, 01:12 AM   #11
Parmas
Parmas's Avatar
I agree the map is too lean even for low boost above 4K. Increase fuel you are risking the motor life drastically.
Also if that was my dyno I would just shift at 5300rpm... after that you are loosing power and time.
Old 01-13-2011, 03:23 AM   #12
Yoda
Yoda's Avatar
Drives: 2008 Black Sedan
I see you are using Torco 107 octane. Was a conversion used to account for that octane to show in the afr? I am using 100 octane so when I see for example 13 afr on my gauge its actually running a bit richer than that. There is still lots more power I feel you can extract from it cause its way lean in the upper part where you power band just levels off. Very good job tho Xb! Thanks for contributing
Yoda is offline   Reply With Quote
Old 01-13-2011, 10:19 AM   #13
stoich yes, at WOT no, better down around 12. Dyno pulls are done at WOT.
Old 01-13-2011, 12:27 PM   #14
Parmas
Parmas's Avatar
I forgot to mention 12 AFR for boost and lower AFR for high boost in case of boost spikes.
Old 01-13-2011, 04:35 PM   #15
Nexus1155
Drives: Audi
Ehhhh, Sweet spot is around 11.* for turbos and theres a bunch of reasoning behind that. Of course you can lean it out and make power, but aiming for stoich, really? you will make more power from having a proper afr and more ignition advance.... Safer too.
Old 01-13-2011, 04:42 PM   #16
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
YAA LEAN IS MEAN!! LOL LOVE IT!
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 01-13-2011, 04:46 PM   #17
scioncrew
scioncrew's Avatar
Drives: SCION tC
love to see what that motor looks like now.
Old 01-13-2011, 05:10 PM   #18
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
+1
Scubaru Steve is offline   Reply With Quote
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 11:26 AM
FS: 2005 Scion xA RS2.0 Turbo uberegg Cars for Sale by private party 40 04-03-2010 11:45 AM
Scion xd turbo PARIS Yaris TS Talk 22 02-26-2010 08:08 AM
Check out the new Scion iQ concept. In the States in 2011/2012 LA Yaris California 9 10-23-2009 08:11 PM
