Old 09-07-2010, 12:42 AM   #1
Nexus1155
Bathroom + Laptop = <3
Drives: Audi
Edit: I just found that P2238 could also mean "Barometric Pressure Circuit Intermittent," when in relation to Toyotas. If this was the case, wouldn't it make more sense to get these two codes together?
Means you're car is seeing boost when its only suppose to see vacuum and the ECU is freaking the hell out.?
Old 09-07-2010, 09:54 AM   #2
Focus_Sh1ft
Focus_Sh1ft's Avatar
Drives: 08 Yaris Turbo; 06 tC Turbo
This must be the case, because my bank 1 sensor 1 functions totally fine as per my narrowband.
pimp my yaris, lemme know what code(s) you have asap. Best case is we have similar codes...
It's interesting that it took a good deal of driving for your code to come on, because it was the same with me. You'd think that if this theory is correct that the light would come on almost immediately. I need to check how the ECU tests for this and determines there's a problem...
Focus_Sh1ft is offline   Reply With Quote
Old 09-07-2010, 05:33 PM   #3
Focus_Sh1ft
Ok, I looked into all this further and realized two things. Firstly, the codes wouldn't come on immediately because it takes two drive cycles for the ECU to determine there is actually a recurring issue. Secondly, I was reading these codes as per the Yaris manual hosted online. P0101 definitely seems to be the maf signal voltage out of range (too high), as a result of boost conditions. As for P2238, the manual lists it as the O2 sensor acting up, not the barometric pressure circuit intermittent. I THINK this is a result of the car running excessively lean. Low positive current on the AF+ wire directly equates to lean conditions. I have a scangauge on the way so I'll run some diagnostics before getting tuned.
Definitely would rather see CELs after boosting than not seeing them. Otherwise the car would clearly just be baffled as to what's happening to it lol.
The cool thing is that if I'm right, a tune will sort out those two CELs. MAF clamping to represent boost conditions, and the proper air/fuel ratio done by fuels map would eliminate P2238.
FS: Autometer Cobalt 6170 Boost Gauge Nexus1155 Items for Sale by private party 2 02-02-2011 04:08 PM
Multiple cylinder misfire under boost LtNoogie Forced Induction Forum 13 11-02-2009 04:44 AM
Fill up with Super before starting your boost project LtNoogie Forced Induction Forum 5 12-01-2008 06:41 PM
Supercharger Selection and Limiting Boost Nexus1155 Forced Induction Forum 1 12-01-2008 03:51 PM
WTB: Boost Gauges Teruyume Items for Sale by private party 4 11-12-2006 02:42 PM
