Old 09-27-2010, 10:26 PM   #1
Astroman
Modded Moderator
Astroman's Avatar
Originally Posted by Slick View Post
The kind that only ones imagination can produce :P oEM ftw lol
That is simply not true, sorry.
Here is a simple article about the difference:
As pulled from articlebase.com
Short Ram Intake
The typical short ram intake is designed with a few key points. First, it has to be easy to install, and typically only requires standard hand tools. Second, it has to increase horsepower while being a relatively inexpensive modification. A short ram intake is called a short ram because it literally is short. The pipe typically is only about 12 to 18 inches in length, and has an air filter on the end.
Short Ram Intake: Chambered Intake Kits
There are short ram intake kits such as the Weapon R Secret Weapon that offer special technology designed to improve air flow to the engine with technology and tricks that the manufacture claims can out perform a cold air intake. These intakes however are typically as expensive as a cold air intake, except you do not need an air bypass valve. The Weapon R Secret Weapon features a built in tube that increases suction and velocity so the manufacture claims increased performance gains over standard short ram intakes. This is a chambered intake kit. Another chambered intake kit that is very popular is the AEM V2 Intake.
Cold Air Intake
The cold air intake is designed to increase horsepower by relocating the air filter outside of the engine bay, typically putting it into the fender. Because the air filter goes into the fender, the cold air is harder to install, but as it's name implies, it allows the engine to take in cooler air, producing more horsepower. Because of the extra complexity of the cold air intake, it typically has higher cost over the compariable short ram intake. Another issue for some, is that the cold air intake could sit low, and suck up water when running over water puddles. This causes hydrolock, and destroys the motor. There are air bypass valves which fix this, but that adds about another $50 in cost to the cold air intake.
Old 09-28-2010, 10:18 AM   #2
Slick
Slick's Avatar
Drives: '09 3-Dr
Send a message via MSN to Slick
That is simply not true, sorry.... Here is a simple article about the difference:
Easy Astro, I was just lightly stirring the pot One may even call it slight sarcasm :)
In a world... where things squeak, wont fit,start to bleed, or are just plain hard to do.... ArmorAll will fix that
Slick is offline   Reply With Quote
DIY - AEM CAI (cold air intake) kurokoma-kun DIY / Maintenance / Service 4 08-16-2009 03:56 AM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 04:16 AM
Intake Systems Decision Maker.. Blenjar Performance Modifications 25 09-15-2007 11:07 PM
AEM Cold Air Intake!!! BulletProofAuto Sponsors Classifieds Area 18 09-19-2006 10:33 PM
AEM Cold Air Intake Toddhata Performance Modifications 18 08-08-2006 04:02 PM
