Old 10-02-2010, 01:07 PM   #27
djct_watt
Drives: 2010 NCP91 5spd
Originally Posted by SimTronik View Post
was talking about this http://shop.microimageonline.com/NIT...ace-RSB-01.htm vs a rear sway bar. Which one is more efficient and should be installed first.. for a everyday driver....
The brace is ineffective for sway/roll reduction without a proper sway bar. What it does is just create massive toe out under heavy cornering (heavy oversteer). It maintains the same horizontal distance between the two suspension points, but does not maintain the same loads, due to the pivots. It's absolutely useless without a sway bar. Just try jacking up one side and you'll see how much out of whack the toe can get with that useless thing. I have it.
Unfortunately, TRD of Japan does not have the Yaris/Vios sway bar available, and the only manufacturer is Ultra-Racing.
DIY - rear sway bar [pics] cali yaris DIY / Maintenance / Service 199 07-28-2022 06:25 AM
Which rear sway bar? IsLNdbOi Performance Modifications 46 11-05-2009 07:07 AM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
Rear Sway Bar Instructions - Additional Pics SeaYa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 02-26-2009 02:05 PM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
