#307 |
Rollerskate
To get full boosted it's all about the turbo you have and your setup
Its a roller-skate get it right add me on facebook if your from nc my email for facebook is drifter704@yahoo.com |
#308 |
It's simply, in one situation the ecu is using pre-determained values to operate the engine and ignores the sensors. The other it's using the sensor readings.
#309 | |
I need more information on this, because it's going to ultimately determine how I go about tuning. EDIT: And allow me to clarify, I understand what the two are. But I'm told that modern cars enter open loop under heavy acceleration, and this is where I need to tune with the FIC, but I've yet to see it happen. |
#310 |
Rollerskate
There is two ways to tune under wot on a dyno or street it really dosnt mater about open or closed loop
#311 |
Hopefully I'm not speaking too soon, but it would appear that my P0101 has gone away.
Ever since I cleaned the corrosion off my battery terminal, it's yet to come back. I also have completed enough driving cycles to determine whether or not there's any pending codes so...
#312 |
From OBD datalogging that PK did some time ago, it seems the main condition for entering open loop is 75% signal from the throttle position sensor. So, put the pedal to the metal!
#313 |
![]() ![]() ![]() ![]() Drives: 2008 Yaris LB Join Date: Jul 2010
Or, maybe CTSCOTT can design something to trick the ECU to think it is always in openloop.
Then we would have 100" control of out cars/tuning withought standalone! GREAT idea, now?
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats." xbgod - 9/23/2010 |
#314 |
There is *potentially* such a trick, the other time the car is in open loop mode is when it's warming up. I've heard of tuners in Puerto Rico doing this, but you could put a resistor in line with the water temperature sensor to fool the ECU into thinking the car is *never* warm, hence it would stay in this warmup mode as long as you wanted. BUT, this is really a pretty dirty hack, I personally have no idea what other effects it may have...
#315 |
Send this to ctscot and lets here his answer!! Can't wait! Then the car will REALLY be tunable w00t w00t!
#316 | ||
![]() This is the information I needed. Quote:
So I'm pretty baffled at this point though. What do I even need to tune? If I don't push the car hard enough to be entering open loop, then that's not really an issue... Afterall, the car runs fine at stoich. |
#317 |
but, where's the fun in driving a turbo'ed car sensibly all the time?
![]() You *could* use a variable potentiometer, or switches, to change the water temp tweaking on the fly, when needed. As for what you need to tune in open loop, there are loads of options out there, personally I would want to get my hands on an inexpensive apexi S-AFC and a wideband O2 gauge to see just how effective this kind of tweaking can be, even without boost (the Yaris does seem to generally run quite rich in open loop mode, might be just mine, but there's certainly some power to be gained by leaning things out at high RPMs)
#318 |
You can pull the second O2 sensor, forcing a constant CEL, then tune the car. That is what ZPI did.
It's a really lame approach, though.
#319 | |
But back to my original question, is tuning closed loop even necessary? Because it's going to be a PITA... Also - I hardly drive "sensibly" lol. But I just don't get it... If I'm not driving hard enough to enter open loop, then wouldn't I be best off just continuing to run stoich? Or is the hotter intake air too dangerous to run at 14.7 at all times? I DONT UNDERSTAND LOL. Last edited by Focus_Sh1ft; 10-04-2010 at 05:45 PM. |
#320 |
The water temp trick will set a code eventually anyways. My parents Matrix set this code on it's own because the thermostat went bad and the car wasn't warming up fast enough. It took a long time to through the code though, as we found it wasn't heating up very quickly for a long time. PS it's only a '03 so I'm sure the Yaris has an even smarter ECU.
#321 |
if you are in boost AT ALL, you don't want to be at 14.7. You should be able to make boost without going WOT.
Clear?
#322 | |
So this means I do need to tune closed loop... So my options are what I originally stated - force the car into open loop or manipulate the O2 sensors. I guess I don't have much of a choice but to start fooling around with the O2 sensors.
#323 |
Rollerskate
Hey focus this is what you need to do not trying to be an ass here but you should take the car to a pro but if you don't want to here are a few thing to remember about tuning 1st it's always easier with two people but not needed ok when you start tuning you want to tune a no load meaning idle like I said before your looking for a a/f of 11:2 to 11:5 I'm not trying to tell you anything wrong if you take Otto a tuner that's what there going to look for so at idle set it around 11:5 after you get that then start with a light load don't get in to boost this is where two people come in hand as your driving cool at your gauges and the pc when you see your starting to leave the sweet zone of 11:2/11:5 then stop make a few changes and start again after you get that set the keep giving it more of a load and more till you have ran put on rpms to play with but always stay in that sweet zone of 11:2/11:5 there is no need to play with the 02 other then with the fic everything can be done with the pc as soon I get my oil leak under controll I well start tuning with my fic and when I'm done I'll give you a full tune of 8psi or what ever psi your running but like I said there is no need to play with the 02 other then using the pc
And for those that think I wrong go ask any pro tuner and the will tell you everything I just said I have tuned using aem before so I know what I'm talking about
#324 |
Rollerskate
Sorry about my spelling I'm using my iPad and it mess-up some of the words
| FS: Autometer Cobalt 6170 Boost Gauge | Nexus1155 | Items for Sale by private party | 2 | 02-02-2011 04:08 PM |
| Multiple cylinder misfire under boost | LtNoogie | Forced Induction Forum | 13 | 11-02-2009 04:44 AM |
| Fill up with Super before starting your boost project | LtNoogie | Forced Induction Forum | 5 | 12-01-2008 06:41 PM |
| Supercharger Selection and Limiting Boost | Nexus1155 | Forced Induction Forum | 1 | 12-01-2008 03:51 PM |
| WTB: Boost Gauges | Teruyume | Items for Sale by private party | 4 | 11-12-2006 02:42 PM |
