Old 10-04-2010, 09:47 PM   #1
Does the key bind, where you can't turn it all the way, or does it turn all the way, but not unlock?
Old 10-04-2010, 10:04 PM   #2
bhola
Drives: 2007 Yaris
Sometime I can not turn key at all. If I can turn it lock works just fine.
Thanks
bhola is offline   Reply With Quote
Old 10-04-2010, 10:09 PM   #3
Thanks
Have you tried a different key and/or lubricating the lock with graphite?
Old 10-04-2010, 10:14 PM   #4
bhola
Drives: 2007 Yaris
I have tried with 2nd key and same results. I did not tried lubricating. Any idea how can I do this? Do I have to take out door panel to lubricate lock and is graphite special brand of lubricant or any lubricant will work?
Thanks
Old 10-04-2010, 10:17 PM   #5
Thanks
You can pick up a little squeeze tube of powdered graphite at an auto parts or home center. You simply stick the tip into the lock, squeeze it a couple times, and then run the key in and out a bunch of times to distribute it.
Old 10-04-2010, 10:22 PM   #6
bhola
Drives: 2007 Yaris
Thanks. I will try it out and post the results.
Old 10-05-2010, 12:01 AM   #7
bhola
Drives: 2007 Yaris
This worked!! Thanks a lot for quick response and your help.
TSB's WD-40 General Yaris / Vitz Discussion 27 06-06-2007 01:11 AM
